CMR question-How to open tune files
send2hussien
Post by send2hussien »
Hi,
Sorry for the dump question, but i am new to CMR,
When i open the software after i press the DCX icon a dialog shows up ((Select fixed/tuning file)) what should i do next???
Should i choose a tune file and a similar template or what???
RE: CMR question-How to open tune files
you need to select the tune files you want to work with...
the "tuning file" is the tune file you'll be able to edit and save changes to - you would usually choose the "last tune written" tune file which is a copy of the diablo tune that the person had installed in the vehicle... or, you could also select the original backup stock tune file to start from scratch...
the "fixed file" is a tune file that you can compare the tuning file to... you usually want to select the original backup tune file for the fixed file....
send2hussien
When i select the file, do i need to choose template??
Because when i select the file ((which is the original back up)) and press OK i receive a windows error and the software crashes.
