need a 6.0 liter turbo brake tune
schuitjongen
Post by schuitjongen »
ok thanks
schuitjongen
hey i was still wantin to know what percent you programmed the vgt to close when off throttle. is it possible to close it down more or not?
SCGt94
Post by SCGt94 »
it's actually a back pressure table in percentage, went up to 200% back pressure.. i suppose i could up it further if you'd like.
Don
2002 WS6
schuitjongen
ok so if it wer closed down as far as it would go what percent would that be? obviously thats too far but maybe another 100 percent. or what would you suggest?
SCGt94
Post by SCGt94 »
well consider this..270% is generated by the turbo at WOT at 3600rpm with a duty cycle of close to .1...which means very close to fully closed.
Don
2002 WS6
schuitjongen
ok
tuningss
Post by tuningss »
If you go much further than that you could get some surging on decel.
http://www.tpctuning.com
dsirekis
Post by dsirekis »
im new to the perdator changed from bullydog looking for info on a custom tune i run a lot of different stuff just if you can shoot me in the right direction nothing seemed just right so im starting here
dave
SCGt94
Post by SCGt94 »
be careful with the bully dog stuff, when they restore the backup i have heard there are problems when switching to another programmer. Word was the bully dog does something to the backup file causing a no start when trying to program with another tuner.
Don
2002 WS6
Smith
Post by Smith »
Don,
Could you set this turbo brake setting in the options area on the predator like the speed limit option in the new crom file? I would be interested in a turbo brake. I imagine that this is a custom tune but with which hp tune? How effective is this brake or is it just for sound?
DS
SCGt94
Post by SCGt94 »
probably won't become an option unless a very large support was shown for it, i have no problem making a custom tune for whoever wants it though, just send me a copy of your original backup. As the author said, it builds back pressure off the gas which will slow you down.
Don
2002 WS6
tuningss
Post by tuningss »
stacked06
Post by stacked06 »
Hey guys. so how do i send you my ori to get this turbo brake tune? i have a six speed stick and wonder how much it will help with braking.
SCGt94
Post by SCGt94 »
IF you already have a tune on the truck, take the pred to your pc and hook it all up. Open DSdownloader and let it find the tool then hit the export tune from tool, it will ask if you want to export your backup..say yes and send me it
Don
2002 WS6
stacked06
Post by stacked06 »
thanks will do
