can't modify tune
bergey
can't modify tune
Post by bergey »
'01 F250 7.3 AT, U7170 Predator, can't get prompt to modify shift on transmission. Install tune comes on screen with no option to modify. Any ideas? Thanks...
cole
Re: can't modify tune
Post by cole »
bergey wrote:'01 F250 7.3 AT, U7170 Predator, can't get prompt to modify shift on transmission. Install tune comes on screen with no option to modify. Any ideas? Thanks...
Did you reciently purchase this predator? We will be offering a update shortly, we have a test vehicle on the dyno as we speak.
Cole Stevens
bergey
RE: Re: can
Post by bergey »
Cole, purchased it 7/25/07, rec'd 7/27. I tried putting 40 & 60 tunes in, restored to stock, and went back to 40 tune, still only get "install tune", no "modify tune". Would the serial # help? Thanks.
Also, I didn't get a manual with the tuner. how can I get one?
cole
Re: RE: Re: can
Post by cole »
bergey wrote:Cole, purchased it 7/25/07, rec'd 7/27. I tried putting 40 & 60 tunes in, restored to stock, and went back to 40 tune, still only get "install tune", no "modify tune". Would the serial # help? Thanks.
On newly purchased predators there is a revision that i am working up. It will have a bunch of transmission parameters.
Cole Stevens
bergey
RE: Re: RE: Re: can
Post by bergey »
Great, thanks!
littlestrokenboy
RE: Re: RE: Re: can
Post by littlestrokenboy »
Yeah, I have the same problem. cant modify tune or trans. Do You have any idea when there will be an update.
cole
Re: RE: Re: RE: Re: can
Post by cole »
littlestrokenboy wrote:Yeah, I have the same problem. cant modify tune or trans. Do You have any idea when there will be an update.
Very shortly. Some more little testing needs to be first to make sure all parameters work as i believe they should.
Cole Stevens
littlestrokenboy
RE: Re: RE: Re: RE: Re: can
K thanks
