09Laramie wrote:
Any ideas or opinions on when to increase fuel vs retarting timing to reduce knock? I'd imagine you'd see the best performance with a balance of both.
well, I tinkered with WOT fuel a couple days ago while waiting for a tune revision. got WOT a/f in the 4-4.8k rpm range to 12.5-12.6:1 and got 2 degrees KR @ 4,300-4,600 rpm. added 1% fuel back in, hope to check results later today.
12.2:1 to 12.5:1 seems to be a good WOT a/f for the Hemi, so if I richen up a/f to 12.2:1 & still have KR, pulling 1-2 deg spark seems like the next logical step.
the right amount of spark + the right amount of fuel = the most power.
09Laramie wrote: Also, does anybody know what the differences are between the 93 tune and the 87 tune as far as timing and fuel are concerned?
no, but you could find out by loading each tune & doing a datalog of part-throttle & WOT driving on each tune.
I'm guessing fuel is similar, 93 has more spark.
