L30 has arrived..
SCGt94
L30 has arrived..
Post by SCGt94 »
Got the templates today, I will let everyone know when i have a test crom made for release..So far i have three cal Id's that are L30 based..
8c3a-14c204-yg
8u7a-14c204-cg
8u7a-14c204-eg
does anyone have a cal id i missed?
Don
2002 WS6
daddygoose
RE: L30 has arrived..
Post by daddygoose »
8U7A-14C204-CG
7U7A-14C337-AB
thanks Don
SCGt94
Post by SCGt94 »
need beta testers for the new crom...email me and i can send you the test crom.
Don
2002 WS6
kamtech
Post by kamtech »
Pick me!!!
8U7A-14C204-CG
7U7A-14C337-AB
phatalex
Post by phatalex »
8u7a-14c204-fd
8c3a-14c337-ca
SCGt94
Post by SCGt94 »
kam yours should be good to go, the crom i sent you should have it..
phatalex, your cal id was not in there, i just added it to the trinity crom, working on predator now...
Don
2002 WS6
SCGt94
Post by SCGt94 »
phatalex....emailing you the new predator crom now..
Don
2002 WS6
Bulldoglover
L30 Codes
Post by Bulldoglover »
#1-8U7A-14C204-CG
#2-7U7A-14C337-AB
oops same as Kamteck I have Diablo predator,, what do I need to do to get my programmer updated and loaded into my trucks computer? I've never used the Diablo preditor programmer.. :oops: Thanks
2008 Ford F250 6.4L Superduty Lariet
SCGt94
RE: L30 Codes
Post by SCGt94 »
oooo so now you need my help! haha, no problem bully dog. The predator needs a usb to serial cable and a 12 volt power supply, we sell them or you can pick them up in stores. Then you can download DS downloader off our website and send the new crom to the tool. Basically you hook the predator up and let it power up...make sure the pc can see it (aka install the drivers that came with your usb to serial cable) then open DSDOWNLOADER, it should automatically find the tool then hit "send crom to tool". Then choose the file that i will email you to send to the tool and you should be good to go.
Don
2002 WS6
concoursd
RE: L30 Codes
Post by concoursd »
don, you forgot to tell him to unplug the power supply to the predator and plug it back in after he selects the file to install into the predator.
SCGt94
RE: L30 Codes
Post by SCGt94 »
^ that too, thanks concoursd
Don
2002 WS6
Bulldoglover
RE: L30 Codes
Don C... You forgot I took up for you and Diblo when I realized the complexity of the L30 Format.. :lol: Any how I have all the necessary hardware, USB to Serial cables etc> I just need the instructions in "laymans' Terms or country boy language.. Thanks for your help. I think I'm going to wait to load the Program untill the Beta test guys give the results to make sure there are no "bugs" :shock:
Andysapp
2008 Ford F250 King Ranch 6.4L- unable to change tire size
Post by Andysapp »
Hi. I have a 2008 Ford King Ranch F250 with 20" tires and have installed 17" winter tires (winter tires are not available in original size). I have tried changing the tire size several different ways (even reverting back to the original tune and going to 900 revs down to 550 revs) and the meter shows the change but the speedometer error doesn't change at all. Is this a problem with the Predator or has Ford locked out tire changes in the computer?
My ids are unit 1: 8U7A-14C204-CF
unit 2: 7U7A-14C337-AB
One suggestion for future croms is the ability to read the lock code as I didn't get it with the truck and would love to be able to access it.
Thanks, Andy.
I have the predator U7164 and use the 80 HP tune
daddygoose
RE: 2008 Ford F250 King Ranch 6.4L- unable to change tire si
don
can you email me the new crom for the 6.4 for the Preditor [email protected]
thanks.
id 8U7A-14C204-CG
7U7A-14C337-AB
SCGt94
Re: 2008 Ford F250 King Ranch 6.4L- unable to change tire si
Post by SCGt94 »
Andysapp wrote:Hi. I have a 2008 Ford King Ranch F250 with 20" tires and have installed 17" winter tires (winter tires are not available in original size). I have tried changing the tire size several different ways (even reverting back to the original tune and going to 900 revs down to 550 revs) and the meter shows the change but the speedometer error doesn't change at all. Is this a problem with the Predator or has Ford locked out tire changes in the computer?
Thanks, Andy.
I believe this is a problem on my end, the tire changes are made to the abs module (as far as ford is concerned) which is obviously not flashed by us. This is my next job i need to tackle. I will let you know when i have a fix for it..
Don
2002 WS6
