What am I doing wrong?
highlife756
I cant get my SLP Predator 7199 to show anything on dataviewer. Everytime I do a log and plug it into my computer I get "An unexpected error has occurred". Any ideas? I have downloaded the revision for it (v.9r02). Car is an 04 GTO. Thanks!!
RE: What am I doing wrong?
post or paste the "runtime.txt" from My Documents\DataViewer folder after you close DataViewer.
Jim
Jim
highlife756
245056260 Info: .\DataViewer.cpp, line 161, CDataViewerApp::InitInstance, DataViewer Version 3.3.0.2 Beta
245056260 Info: .\DataViewer.cpp, line 162, CDataViewerApp::InitInstance, The DataViewer is initializing.
245058881 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
245061767 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
245065402 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 44
245069801 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
245071159 Warning: .\data\VehicleIdent.cpp, line 302, CVehicleIdentifier::ParsePartNum, Unknown tool part number: slp7199
245080955 Assert: .\data\LiveDataBase.cpp, line 90, CLiveDataBase::SetUseBus, Assertion Failed!
245090128 Info: .\DataViewerDocFileOps.cpp, line 537, CDataViewerDoc::DoPromptForFiles, Log Data Download
245090144 Warning: .\data\VehicleIdent.cpp, line 302, CVehicleIdentifier::ParsePartNum, Unknown tool part number: slp7199
245090144 Assert: .\data\LiveDataBase.cpp, line 90, CLiveDataBase::SetUseBus, Assertion Failed!
245090175 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
245163121 Info: .\DataViewerDocFileOps.cpp, line 839, CDataViewerDoc::OnLogDownloadSuccess, Log Data Downloaded
245163262 Info: .\DataViewerDocFileOps.cpp, line 922, CDataViewerDoc::OnLogDownloadSuccess,
245163262 Info: .\data\PidRecordMgr.cpp, line 89, CPidRecordMgr::Load, Begin Load() of data for vehicle - GM - - - : CALID =
245163324 Info: .\data\PidRecordMgr.cpp, line 93, CPidRecordMgr::Load, Reading pid records, found: 507
245163418 Assert: .\data\LiveDataBase.cpp, line 90, CLiveDataBase::SetUseBus, Assertion Failed!
245163433 Info: .\data\PidRecordMgr.cpp, line 89, CPidRecordMgr::Load, Begin Load() of data for vehicle - GM - - - : CALID =
245163433 Info: .\data\PidRecordMgr.cpp, line 93, CPidRecordMgr::Load, Reading pid records, found: 507
245163449 Error: .\DataViewerDocFileOps.cpp, line 1041, CDataViewerDoc::OnLogDownloadSuccess, An unknown exception ocurred.
245163449 Error: .\DataViewerDocFileOps.cpp, line 1049, CDataViewerDoc::OnLogDownloadSuccess, Sorry - an uknown problem has occurred.
245676146 Warning: .\comm\CommThread.cpp, line 359, CCommThread::ShutDown, Shutting down communications...
245676411 Info: .\comm\CommThread.cpp, line 176, CCommThread::ExitThread, CommThread::ExitThread complete.
245676411 Info: .\DataViewer.cpp, line 285, CDataViewerApp::ExitInstance, CDataViewerApp::ExitInstance complete.
highlife756
Yep! Vista presents problems with accessing Serial/USB ports when running with a restricted user account. See the DataViewer FAQ re: "I have Windows Vista", for possible work-arounds:
http://www.diablosport.com/index.php?na ... pic&t=2396
Jim
Jim
