IMO this needs fix'in - external PID logging
LouZ
I got a AFR input to my trinity logging AFR.
When not hooked up to the car and playbacking the log, the External PID does not show up. When hooked up it shows.
This is a problem. When sSending logs to my email tuner he does not see the external PID.
What I have to do is when hooked up...export the log to a csv file.
The problem with this is the csv file is huge.
Lou
Lou
RE: IMO this needs fix
Are you using the latest DV Beta release that had a fix for this?
LouZ
Re: RE: IMO this needs fix
yes I'm using 3.3.02 betamikel wrote:Are you using the latest DV Beta release that had a fix for this?
RE: Re: RE: IMO this needs fix
grrr...I was under the impression this was fixed??
That doesn't sound right. You should be able to playback the log on DV; without being connected to Trinity.
Please post your log and will investigate.
Jim
Jim
wait a minute...what version is on the Trinity?
LouZ
Re: RE: Re: RE: IMO this needs fix
I have 1r06 with the 1r06a-u7135 updatemikel wrote:wait a minute...what version is on the Trinity?
LouZ
jimb wrote:That doesn't sound right. You should be able to playback the log on DV; without being connected to Trinity.
Jim
LouZ
LouZ
I can play back the log but I only see the external pid when hooked up to the carjimb wrote:That doesn't sound right. You should be able to playback the log on DV; without being connected to Trinity.
Jim
RE: Re: RE: Re: RE: IMO this needs fix
I get critical file error from DV. Does this log playback for you in DV? Without Trinity attached?
Re: RE: Re: RE: Re: RE: IMO this needs fix
The critical error is prolly the forum messing up the file, please reach over and slap the guy next to you and ask him to fix this once and for all, PLEASE.jimb wrote:I get critical file error from DV. Does this log playback for you in DV? Without Trinity attached?
RE: Re: RE: Re: RE: Re: RE: IMO this needs fix
yeah man... file downloads from the forum are STILL sucking...
OK. I just tested this using 1r06a_u7135 and with an SRT-8 bench ECU and power supply. It works fine. Even IF you download the log file from Trinity, save it on PC with DV and disconnect Trinity. You can restart DV and log plays back showing External INputs. Attached is a procedure and pictures.
Jim
Jim
