How can I better my ST Retard?
steve128h
Post by steve128h »
I have done some data loggin and found that at about 5000 RPM's, I get a ST retard of 4 deg. Is this normal? what can I do to better this?
gizmodo
RE: How can I better my ST Retard?
Post by gizmodo »
A little information about the vehicle would be helpful.
09Laramie
Post by 09Laramie »
4 degrees is definitely higher than desirable. Generally adding fuel or pulling spark in the rpm range that it's happening in will reduce the knock retard
steve128h
Post by steve128h »
Thanks for the help 09Laramie. I will try the fuel first and see what that gets me.
