i get the cal_id 05073546AK will and update fix this? also will the update add more tunes on my predator? what extra tunes can i get with the update from here http://www.diablosport.com/index.php?mo ... #downloads and i have an edge EZ i can stack is this a safe stack? which tunes should i use? edge will be on 65HP, or should i just sell it and buy a 60-90HP puck?
okay i jsut found this, http://diablosport.com/index.php?name=P ... pic&t=1193
which one should i download? pre r28 or post r28? im not sure how to tell?
2003 predator wont load, and stacking question
motoman006
RE: 2003 predator wont load, and stacking question
Sounds like you need to update, then use the post r28 tunes...
motoman006
Re: RE: 2003 predator wont load, and stacking question
thats what i gathered after reading around for a while, also, is edge EZ a safe box to stack with the predator? if so which tunes should i use the stacker tunes or the regular tunes? Thanks againmikel wrote:Sounds like you need to update, then use the post r28 tunes...
andygill17
RE: Re: RE: 2003 predator wont load, and stacking question
i've got a 2003 with the extreme RKL puff tune stacked with an EZ on the 60hp setting. Runs really strong, but I need a F.A.S.S. or something similar as it will starve the cp3 in the lower gears. In 5th and 6th it's got enough time for the cp3 to "keep up". it takes a while to learn how to drive without smoking everyone out, but it is possible.
'03 cummins 6spd
con FE clutch
predator
Edge EZ
con FE clutch
predator
Edge EZ
motoman006
im running twins with flux 1.8 injectors RKL tune and a stage II CP3 truck is easy to drive and not smoke everyone out with the twins, im just looking for more power i was thinking the MP-8 or edge EZ oh and i also have an air dog on the truck i have no dueling problems in any gear
andygill17
mp-8 would be preferable as you can adjust it or even turn it off from in the cab. only reason I have the EZ is because it was already on the truck when I got it. It's a pain to change settings..you've got to pop the hood, open up the EZ and move a jumper clip thing. newer EZ's may have in-cab adjustability, not sure though.
and just to clarify, i'm running the regular rkl puff tune, not the stack one. it's been running strong for the last year or two, but I think the rail pressure is getting a bit high...after you let off the gas (to shift, when you're really getting on it) it'll rev up to 3500rpm and stay there for a second or two.
'03 cummins 6spd
con FE clutch
predator
Edge EZ
con FE clutch
predator
Edge EZ
MP-8? Why not go with our EPP?
Check out the features, and the cost....
motoman006
Re: RE: Re: RE: 2003 predator wont load, and stacking questi
i planed on it but my buddy has a edge ez that will work with my truck and i can get it for $130 bucksmikel wrote:MP-8? Why not go with our EPP?
