Were you able to re-create the problem?jimb wrote:OK. Now I understand the sequence your using and can re-create what the issue. I need to "fire-up" the debugger and look into it.
Jim
IMO this needs fix'in - external PID logging
LouZ
Re: RE: Re: RE: Re: RE: test
RE: Re: RE: Re: RE: Re: RE: test
I believe he was, as I know he is working on a dataviewer update to fix a few other issues as well... and it will probably be released at the end of the week...
Yes, I can re-create the problem that LouZ is experiencing.
LouZ
Re: RE: Re: RE: Re: RE: Re: RE: test
Just making sure it's not mejimb wrote:Yes, I can re-create the problem that LouZ is experiencing.
RE: Re: RE: Re: RE: Re: RE: Re: RE: test
The problem is External Input channel designation and converter tranforms are read from Trinity while connected and not saved for later playback. So, when you later playback a log containing External inputs (without a Trinity attached); DV has no convertor information for enabling External input labels. That's why when you attach Trinity, your external inputs re-appear.
EXACTLY what I was thinkin'!!
Dataview release 3.3.0.3 Beta as been released. It addresses the issue LouZ reported by properly capturing External/Analog configuration in the DV log file during recording. This allows for proper playback without the need to have Trinity connected.
