L 30 test crom 9t12c feed back
phatalex
Post by phatalex »
Don,
Here is some prelim results for the new L30 crom.
My driving habits are easy on the throttle and 90% HWY @ about 100 km/h
I loaded the 9t12c the other day using the 80 hp setting I found:
Truck went into regen after about 5 minutes. Thought it was just a fluke but then it cycled again the next day.It quits regen and then resets itself when I turn off the engine but cycles again after a few minutes. The truck on stock would regen about 2-3 times per tank or about 500km's.
Turbo on stock on a flat hwy w/no wind between 6-8 psi.
turbo on 80 hp tune 11-12 same conditions
I only ran this tune for about 60 km's or so but I want to go back to stock to see if it regens so often.
I did complain a few months ago to the dealer that I used to get 600km to a tank and now I was lucky to get 500km. I had mentioned the EGR but they refused to replace it. After telling them that my boost was running about 10 psi they asked me to drive 'er hard. This is after I had mentioned my grandpa driving habit.So I went out and thrashed the crap out of her for about 30 minutes of lots of acceleration and high revs. Well guess what??, my stock boost went down! So did I get better fuel economy? NOPE! At least my turbos are decarbed LOL
I was hoping that this new tune combined with my lower boost would give me that 600 kms per tank again but I'll never get it if it keeps regenerating.
Need more feedback on this latest tune from other Betas.
Good luck Don!
Sorry for the long winded post
Bulldoglover
RE: L 30 test crom 9t12c feed back
Post by Bulldoglover »
Don C, I tried to up load the latest Diablop predator for the L30 verson off this site, is Revision 12 out? The download on my unit shows R.11 just shows Rev 11..Please adivse
PS what does "regen" mean on the above post?
2008 Ford F250 6.4L Superduty Lariet
SCGt94
Post by SCGt94 »
regen means the regeneration of the particulate filter. The 80hp and 100hp will effect how boost come on, so that seems normal in the above post. Phatalex, try some seafoam to try and take care of any carbon and soot build up. Then try the economy tune, boost should be a bit lower...
Don
2002 WS6
phatalex
Post by phatalex »
I tried the econo tune (50hp) and still goes into regen every trip guzzuling a nice 22l/100.
Two days ago I put it back to stock because I was sick of losing all that fuel. It's no longer regenerating in stock after about 90km's
We know these 6.4s are sensitive to regen but WTF!? what a pain in the ASS!
Is no one else testing this crom. I was "lucky" enough that my dealer did it for me without telling me when my truck was in for a seatbelt issue.
SCGt94
Post by SCGt94 »
could be the l30 in general is now more sensative. Granted these tunes are based off the l20 stuff so the l30's may need further tweaking/changes. The l20's were pretty sensative to regen as well, some trucks would do exactly the same thing as yours and others ran like a champ with no problems at all. How many miles are on the truck phatalex?
Don
2002 WS6
5.9D
Post by 5.9D »
Don,
I posted on the Trinity and this is a U7165 Predator we are trying to install.The U7165 just said vehicle not supported.
Pulled the truck part number with a Triple Dog. The truck part number is vxcf9h7 on a 2007 F350 6.0L
concoursd
Post by concoursd »
Bulldoglover
What does "REGEN" mean ?
SCGt94
Post by SCGt94 »
rengeration of the particulate filter in the exhaust...
Don
2002 WS6
SCGt94
Post by SCGt94 »
...or "cleaning" of the filter if you will
Don
2002 WS6
phatalex
Post by phatalex »
Don,
The truck has 45,000 km's on it.
I have been running stock for the last couple of weeks with the usual cycles of regen(about 2-3 times per tank)
Would you like me to try econo again to see if it regens more frequently?
SCGt94
Post by SCGt94 »
yea the econo has quite a bit less fuel in it and also a tad more timing limitations removed. These engine do NOT like timing, they start to buck and shudder if you add to much
Don
2002 WS6
daddygoose
Post by daddygoose »
heres some info on the stock L30. for some reason the computer has quit going into regen. in the last two months i have seen it one time. it had the service engine light on for about an hour two weeks ago and then went off. havent seen it again. and now the drain water separator light is on . but i have drained it twice and still coming on. these are just some of the problems im having from my stock 6.4. For this reason im scared to put the preditor on it yet. cant afford to buy a new motor.
phatalex
Post by phatalex »
daddygoose
Since getting flashed the l30 I have noticed that when it goes into regen it displays only for a few seconds where as previously it would stay displayed in the instrument cluster the entire regen cycle. I also get a message that says "drive to clean filter"(or something like that)
I have no doubt when it cycles as you can feel the power loss and here the back washing type of sound when you throttle it and back off quickly.
I would say if you have warranty it's time to pay the dealer a visit to resolve your warning lights.
Bulldoglover
Don C is Rev 12 out for L30 ?If so could you please send it to me? Thanks
