2002 LS6 Camaro Programming
2006Silverado4x4
Post by 2006Silverado4x4 »
I have a 2002 Camaro Z28 6spd with a newly installed factory GM LS-6 part#89017653. It is currently running with the stock LS1 tune and stock LS1 injectors. It has had long tube headers installed, SLP MAF and Air intake and a Fast LSX intake. It seems to be running great right now, tons of power and 25+ MPG, passes smog with flying colors. I am worried it may be running a little lean. I am wanting to run an economy/performance tune similar to the one I use with my 2006 Silverado and the U7192 programer. The gears have been changed in the Z28 and the speedo needs correcting as well, so, is there an off the shelf tuner I need to buy, do I need to buy a custom tuner or just have someone do this for me at a performance shop?
RE: 2002 LS6 Camaro Programming
The U7198 will work perfectly for you.
2006Silverado4x4
Cool, thanks for the advice Mike, I just bought one and will try it out asap.
Return to “Trinity GM Gas”
