logging with my laptop
05durango
Post by 05durango »
u7137-9t06d fixed majority of my problems. Prior to this it wouldn't even read the calid and I couldn't load a tune.
Now that it's fixed and i've been doing some tuning and logging but I can't live log using my laptop. I can log with the pred until it's full...and I can download and read what was logged. But when I try to log with my laptop hooked up, it acts as if it takes a quick snap shot of the log then stops. I've tried disconnecting/reconnecting but when I do, dataviewer locks up and stops responding. I've tried both the production and beta version of dataviewer...both have the same issue.
Any suggestions?
05 Durango
JBA headers, hi-flow cats, Magna flow, K&N cold air
jimb
RE: logging with my laptop
Post by jimb »
Please post (or paste) the contents of runtime.txt file found in "My Documents\DataViewer".
05durango
Post by 05durango »
I'll post it as soon as I get home today.
05 Durango
05durango
Post by 05durango »
runtime data below.
188215065 Info: .\DataViewer.cpp, line 161, CDataViewerApp::InitInstance, DataViewer Version 3.3.0.2 Beta
188215065 Info: .\DataViewer.cpp, line 162, CDataViewerApp::InitInstance, The DataViewer is initializing.
188215284 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
188217702 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188222663 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188223115 Info: .\DataViewerDocFileOps.cpp, line 86, CDataViewerDoc::OnOpenDocument, Loading C:\Users\User\Documents\DataViewer\logs\05 Durango - can 93oct - LOG 01 12-1-09.log
188223739 Info: .\data\PidRecordMgr.cpp, line 89, CPidRecordMgr::Load, Begin Load() of data for vehicle 2005.0 - Chrysler - - - : CALID =
188223786 Info: .\data\PidRecordMgr.cpp, line 93, CPidRecordMgr::Load, Reading pid records, found: 2100
188224098 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
188224347 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
188227608 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188232553 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188237498 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188242428 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188247373 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188252318 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188257264 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188262209 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188267154 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188272099 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188277045 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188281974 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188286935 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188291880 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188296810 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188301755 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188306732 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188311661 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188316622 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188321567 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188326512 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188331458 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188336387 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188341333 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188346278 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188351239 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188356184 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188361145 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188366121 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188371066 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188376012 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188380957 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188385886 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188390832 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188395793 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188400738 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188405683 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188410628 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188415573 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188420519 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188425448 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188430394 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188435339 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188440284 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188445229 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188450190 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188455135 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188460081 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188465010 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188469955 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188474901 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188479861 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188484822 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188489768 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188494713 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188499674 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188504603 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188509548 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188514494 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188519439 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188524384 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188529329 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188534275 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188539220 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188544165 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188549126 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188554071 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188559016 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188563962 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188568907 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188573852 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188578797 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188583743 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188588688 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188593633 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188598578 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188603508 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188608453 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188613398 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188618344 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188623273 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188628218 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188633148 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188638093 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188643023 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188647968 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188652929 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188657859 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188662804 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188667765 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188672710 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188677655 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188682600 Error: .\comm\CommThread.cpp, line 491, CCommThread::TestOpenConnection, Baud Check bad response: 5A
188687171 Info: .\comm\CommThread.cpp, line 176, CCommThread::ExitThread, CommThread::ExitThread complete.
188687171 Info: .\DataViewer.cpp, line 285, CDataViewerApp::ExitInstance, CDataViewerApp::ExitInstance complete.
05 Durango
check the baud rate setting of the cable in Windows Device Manager...
make sure it's set to 115,200.... if it isn't, then change it so that it is...
reboot, then try logging again..
05durango
Post by 05durango »
tried changing baud rate...didn't fix it.
it starts to log...but stops about 1.5 seconds into it....then at the bottom right of DV screen it says "transfering data" (don't quote me). Once this happens I can let it sit for 10 minutes and it does nothing. I try to disconnect and re-connect and DV crashes and I'm forced to reboot.
this sucks...really would like to log with my laptop.
I'm using a cerial cable...do you think that could be the problem and I need to try the usb?
05 Durango
injectionperf
Post by injectionperf »
Have you tried logging to the predator then uploading it to the DV for playback?
05durango
Post by 05durango »
I have no problems logging to the pred and then downloading to DV.
I've tried everything...all the windows vista recommendations found in FAQ, firewalls, security settings, baud rate, etc.
When I hook up with my laptop, it logs the first 1.5 seconds...then stops for 10-15 seconds, then says "transfer in progress" on the status bar in the bottom right corner of the screen. If I stop recording prior to it saying "transfer in progress", I can play the 1.5 seconds of recorded data. But once it says "transfer in progress", DV locks and stops responding. I have to alt,ctl,del to proceed any further.
But again...I have zero problems logging on the pred and downloading with DV....just problems when trying to view live data.
Come on guys...surely someone has had this issue before.
05 Durango
akatoad
Post by akatoad »
I am having the same problem. I am running xp on my laptop. It acts like it just takes a snapshot.
jimb
Post by jimb »
Try updating to recently released u7137-9r06. There was a correction made for SCI based ECUs that affected live streaming with DV.
Be sure to follow the crom update procedures.
Jimb
Return to “DataViewer/DV2”
