unknown fault code nd 0026
ibew112
Post by ibew112 »
predator wc7198
2002 silverado 8.1L
whipple supercharger with whipple morphed pcm
I am getting mass air flow codes p0102 I believe anyway maf low voltage code
second code is evap emmission control purge valve then this unknown fault np or nd 0026
after a 10 minute run the truck refuses to start unless it sits for 30 minutes even after clearing the codes
or last night i reinstalled the tune and it fired right up
Tired of high performance engines. please help
RE: unknown fault code nd 0026
Is it a stock MAF?
Check for leaks around the MAF or blower inlet.
Return to “Predator GM Gas”
