diablo u 7130+puck? setting for stock tranny?
blackmagic1
Post by blackmagic1 »
hi guy's, i m looking for buying the puck?
i can use the power puck with predator u 7130 with stock tranny? or is bad idea?
i want use the tune tow(65 hp) and puck, because i want reduce the low lags!
i check the power puck feature ,and the HP is flywheel? not RWHP, is that made a difference betteween hp and rwhp?
you could tell me the best setting puck +U7130
(i m has pillar gauges )
and difference betteween extreme puck and std puck?
thank
kw5.9
Post by kw5.9 »
stock tranny....better leave the puck alone for now, anything over the tow tune will prematurely wear your tranny...fast! I believe the differance in pucks is the EPP does boost fooling and has 10hp and has a dial, instead of the switch, but if it was me I would plug it up and take my chances, if you drive nicely the tranny may last a long time, its up to how you drive. 8)
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
duckslayer
Post by duckslayer »
Stock Tranny, I have Predator Performance Moudule, 60hp towing and 100 hp performance, I have a Predator U7130 that I run anywhere from tow to extreme and have not had a problem yet, I was told by a tranny guy that if I Change my oil once or twice a year it should last, I also have a AFE qiuckfit filter, 5 " exhaust, Pillar gauages a must, to keep the tranny from geting to hot. Side winder steps, Air ride system, No catalyst converter. I should also mention that I have had this on my truck since it was new, only 2,000 miles on it, tow an 15-18k trailer, Automatic, I have 47,000 miles on it now. I expect to have a problem since I read everyone else has one, so I have my tranny guy on stand by to rebuild me one that will take 1,000 hp if and when I need it
motoman006
Post by motoman006 »
stock tranny will not hold up to real power, just save you money upgrade you trans, then stack it and put whatever else you want on the truck
duckslayer
I hate to dsiagree but I am running about 780 hp with the stock tranny, Just take care of it. They are made for up to 550 hp they told me so, I don't race it all the time but, I won't let a chance go by with out taken the challange. Haven't lost yet, Just having fun and doing it in the right places so no one gets hurt. By the way mine has been doublestacked since it was new, now 47,000 miles and pulls an 18k toyhauler. Goodluck!
ropnjessi
Post by ropnjessi »
duckslayer wrote:I hate to dsiagree but I am running about 780 hp with the stock tranny, Just take care of it. They are made for up to 550 hp they told me so, I don't race it all the time but, I won't let a chance go by with out taken the challange. Haven't lost yet, Just having fun and doing it in the right places so no one gets hurt. By the way mine has been doublestacked since it was new, now 47,000 miles and pulls an 18k toyhauler. Goodluck!
780HP on a stock transmission?? Is this RWHP, you've dyno'ed this? What year and mods are on your truck exactly? My guess is your around the 450hp mark.
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
motoman006
http://www.diablosport.com/index.php?na ... ic&t=19228 dont sound like 780HP to me, and a 48RE will hold around 400 to 450 stock and its still not good to load programmer on them
andygill17
Post by andygill17 »
the "two scoops and ghost flames on front" add 350hp...haha
'03 cummins 6spd
con FE clutch
predator
Edge EZ
benhilt
Post by benhilt »
My tranny is toast, just on extreme 50000 miles .My new stage 4 should be done in a few weeks.Cant wait.
mhshaffer
Post by mhshaffer »
I put my 7130 on around 22K. I went on a 8K vacation pulling a 30' 5th wheel. I have Apost gauges and watched my trans temp..
When I returned I had 75K on the trans. it was shifting funny. It would shift hard and also shifted sloppy. Took truck to dealer and found out trans was toast. The torque converter was shot and had taken out the tranny. Dealer trans tech said any power over 400 hp @ the flywheel wasn't good. Using the tow program (70hp) should be ok, but don't push it much beyond that. 100hp over stock if you don't go hog wild on stop and go heavy foot. I now use 100hp setting with an egg between my foot and pedal and 70hp when I tow, also with an egg. I now have over 110K miles on the truck, so far no problems. Just make sure to change trans oil and filter every 25K or so.
