Predator U7194 Fuel Slope Data Problems
2sscamaro
Post by 2sscamaro »
Predator U7194 Revision 9r10 2010 camaro L99
I've been suspect of my fuel slope LTFT's since I purchased the tool a couple of weeks ago. I have attached today's cruise log and as you can see the numbers don't change low to high and bank to bank. When you look at it in DSLogRedux it shows no data at all :shock: . If I vary the throttle position the LTFT's change from positive to negative but in steady cruise "0". Any Ideas? Can just a single parameter's data not be picked up correctly by the tool? I was headed over the the strip tonight to conduct some WOT logs but I don't nkow now if I would be wasting my time. What do you think. Also would you add, delete or keep the parameters I chose?
2SSCamaro
RE: Predator U7194 Fuel Slope Data Problems
yeah... redux says "no data" because your ltft's are all 0 already....
when finding the "average" ltft's of the data, any rows of data that have a 0 ltft value, are thrown out/not used...
so, since yours are ALL 0's, it's all thrown out/not used, and therefore, "no data"...
have you adjusted your slope at all?
Return to “Trinity GM Gas”
