Getting remote start added in...
sircolby45
Ok I am getting an advanced remote start adding into my truck next week.(I currently don't have any remote start at all) Anyway I was wondering if there was anything I should be worried about with my program. I realize that I probably need to pull it out prior to going up there, but is there any reason at all that this program will give me any trouble going back in, or any trouble with their reprogramming for the remote start?(For example is this tune going to mess up their reprogramming whenever I put it back in)
Also I am currently running the pre 9r05A(or whatever the new update is that revised the tune) and I was wondering if I should go ahead and update it while I have it pulled out? The tune I have has been working great, but if there is a decent power gain to be had and hopefully no headaches then I will go ahead and update it.
RE: Getting remote start adding in...
when you go to reinstall the tune, you may have issues due to the aftermarket remote start setup...
you will need to pull out the fuses for it to disable it before attempting to tune/flash your truck...
sircolby45
Re: RE: Getting remote start adding in...
It is made by GM. It is just the advanced 2-way system instead of the regular remote start. Any idea on what I need to be looking for on a fuse to pull? I think I have heard that they will program a module called the BCO.(Or the dealer called it the Body Control Module)06MonteSS wrote:when you go to reinstall the tune, you may have issues due to the aftermarket remote start setup...
RE: Re: RE: Getting remote start adding in...
yeah... you'll need to restore the original backup tune to the vehicle before you bring it in....
and not sure about the fuse...
and even tho it's made by GM, it's still an "aftermarket" item... it's not the factory system, and it's a different 2-way system...
the power draw on aftermarket systems is usually different, and usually constant, even tho small, which causes issues when trying to flash a tune to the vehicle...
joeyz71
Hey sircolby45, I'm glad you posted this cause I really need (want) a remote starter for these cold winter months to come. Good info!
get ready for headaches when installing your predator or changing settings. remote starters are a PITA with power draws.
sircolby45
Re: RE: Re: RE: Getting remote start adding in...
concoursd wrote:get ready for headaches when installing your predator or changing settings. remote starters are a PITA with power draws.
I reject your reality and substitute my own.
RE: Re: RE: Re: RE: Getting remote start adding in...
I am just giving you a heads-up. Once people figured out which fuses to pull it is not an issue but impatient people will get frustrated.
sircolby45
Re: RE: Re: RE: Re: RE: Getting remote start adding in...
I shot Johan a PM to see if he knows what fuse to pull. So maybe he will know what fuse to pull.concoursd wrote:I am just giving you a heads-up. Once people figured out which fuses to pull it is not an issue but impatient people will get frustrated.
joeyz71
RE: Re: RE: Re: RE: Re: RE: Getting remote start adding in..
So ya know, I had a remote starter on an '01 Silverado and never had any problems w/ any aspect of tunes... never needed to pull fuses or anything. I don't really see why there would be any parasitic draw if it's not an alarm too.
CANUCKPREDATOR
There is draw, because it is sitting there waiting for a signal to do its job. Programmers are VERY sensitive to power draws/loss, which can cause the ECM to turn into a brick. Now I'm not a mason, but I can pull a fuse. Which do you think is easier on the wallet, new ECM or pulling a fuse?
joeyz71
Re: RE: Re: RE: Re: RE: Re: RE: Getting remote start adding
Really? Well for me it's obvious... ECM's are cheaper maybe if ya own a boneyardCANUCKPREDATOR wrote: Which do you think is easier on the wallet, new ECM or pulling a fuse?
Simply stating MY past experiences
CANUCKPREDATOR
RE: Re: RE: Re: RE: Re: RE: Re: RE: Getting remote start add
I'm simply stating the facts.
sircolby45,
the fuse number will depend on what the installer uses to tap into for power. The best thing to do is to ask your installer to show you/write down the fuse location for the connection.
joeyz71
Right... can, doesn't all the time as in my instance.CANUCKPREDATOR wrote:There is draw, because it is sitting there waiting for a signal to do its job. Programmers are VERY sensitive to power draws/loss, which can cause the ECM to turn into a brick. Now I'm not a mason, but I can pull a fuse. Which do you think is easier on the wallet, new ECM or pulling a fuse?
Now
