which version is better
eddieray
Post by eddieray »
which version is best on the u7135...i have a 2007 5.7l hemi and I run the 93 cai tune from version 9r20r...is there any difference in the canned tunes from an earlier version?
RE: which version is better
earlier versions are probably not as good as the latest versions, that'd be the difference...
if they update the tunes to improve them, they'd always be in the latest/newest revisions...
eddieray
Post by eddieray »
yeah that would seem to make the most sense...thanks Monte.
np man, you're welcome...
yeah, the same holds true for the latest GM updates they've done... they updated all the tunes in the latest revisions while they updated other things...
so, as long as you're on the latest revision for your tool, you've got the best tunes that are available...
Cruisin1966
Post by Cruisin1966 »
Well, I would take that with a grain of salt. Not trying to be a sh!t disturber, but a lot of folks (with the 06s and 07s) have reported their cars run better with the older CROMs. I just picked up an 07 Sublime Daytona and will begin with the 9r08 CROM. There are benefits to these older CROMs, not the least of which is the ability to turn off the rear O2 sensors, EGR, etc.
2007 Sublime Daytona #082/150
McKinney catch can (to be installed)
I actually liked 8t16a the best. Unfortunetly that was before the logging was working right and alot of other stuff.
fireman2118
Post by fireman2118 »
The newer version fixed problems with new model cars. The canned tunes for your '07 are going to be the same.
'05 Magnum R/T - 400 rwhp - 385 rwtq
PPP stage 3 heads, Howards cams 219/227 .600/.575 112 +4 , Ported 6.1 intake manifold, 85mm TB, JBA headers & mids, Corsa Sport, Dominator 3000 stall TC, stage II valve body, Getrag 3.91 LSD, BCR coilovers, Eibach sways, BWoody links, Wilwood big brake kit
DGatzby1
Post by DGatzby1 »
X2
I am using 9r12 on my '06. The newer versions seem to just cause problems, plus DS have not improved any of the performance parameters since 9r06.
2006 300C-SRT
185 T-Stat/Catch Can
DiabloToona CMR Gas tune
Extra "Flex" E-85 tune
bigsnake
Post by bigsnake »
I'm running 9r13 on my 09 Challenger SRT and it's doing fine. Believe that because it's new doesn't always mean it's better. Also I try to keep a version of all of them in a file just in case.
Bigsnake
10 Charger SRT8
11 Mustang Shelby GT500
