Version software is revision incompatible for tuning
GamblerZ
Post by GamblerZ »
I have an '05 Chev. Avalanche LT that is no longer accepting a tune after returning from the dealership. I restored the stock tune prior to bringing it in and am now getting the following message:
Call you dealer for tech support
Model No. GM-2004
Predator Serial No. 000324
Tool ID No. 9819499DF681F504
Software Rev 2.04
Hardware Rev 1.01
Factory Tune
Tool is locked
'05 Chevrolet Avalanche LT
GamblerZ
RE: Version software is revision incompatible for tuning
Post by GamblerZ »
I should note that I just got the truck back from the shop for Error Code P0894. The entire transmission was rebuilt due to clutch and solenoid failure. Additionally, they adjusted my settings for the 20" wheels I had installed.
Goatluver
Post by Goatluver »
Dealer most likely flashed the PCM to GM's latest version.
Here is a website that you can check: http://tis2web.service.gm.com/tis2web
05 GTO - M6
U7191 ver 9r02
08 - Avalanche LTZ
i1000 ver 1r04g
Gambler, please post up the 8th digit of your VIN so I can tell you what revision to request when you send that tool in.
GamblerZ
Post by GamblerZ »
I'm assuming you are looking for what is in the 8th spot of the VIN. That would be "Z". Otherwise, if you are looking for the 8th number, then it would be "2"
OK, you'll need to fill out an RMA request from our website and have the tool updated to the 2.10 revision to fix this.
Did you restore the stock tune to the truck before the dealer reflashed it?
GamblerZ
Post by GamblerZ »
Yes. It was my understanding that you should always restore the factory tune prior to servicing to ensure that the Modified Tunes are available on the Predator. Is that not correct?
GamblerZ
Post by GamblerZ »
RMA message sent/received.
Return to “Predator GM Gas”
