1r06b Driveability Issues..
Post questions/comments about your Trinity for your Ford diesel truck.
RAAEEEVO
Post by RAAEEEVO »
After updating to VXCF9 and 1r06b test crom, I have been experiencing extended time between shifts, hard shifts, over 1 MPG decrease from stock tune, and lack of power... sometimes I can't get over 70MPH. (On 100 HP).. when I restore stock tune, all is well...
Just a bit of info for those working on the tune...
2005 Ford F350 6.0L
...... Pennsylvania... currently 27 degrees...
SCGt94
RE: 1r06b Driveability Issues..
Post by SCGt94 »
hmm interesting. Let me check it out, ill get back to ya
Don
2002 WS6
SCGt94
Post by SCGt94 »
Going to need you to do a favor for me, log injector pressure and VGT duty cycle, see if they change while on the 100hp tune.
Don
2002 WS6
RAAEEEVO
Post by RAAEEEVO »
ok... thanks.. gonna road test now, get back to ya in a few...
RAAEEEVO
Post by RAAEEEVO »
VGT Duty Cycle range: .24 - .78
Injector PSI: 4.0 - 28.25
0-50 mph range... values were the same with Stock and 100 tune.
.......................... acts as though its not downshifting to passing gear.....
SCGt94
Post by SCGt94 »
ok so vgt and injector is doing what its supposed to. We have no tcm control (other then commanding more shift pressure in the tunes) so the tune shouldn't affect shift timing at all. Hmmm, this is the only time i have seen this problem. But you say all is well when you get back to stock right? When was the last time a tranny filter was done? The truck may not like the extra tv pressure i am commanding in the tune which may be why it seems to be better when you go back to stock? Wild guess at that point, have seen it happen once or twice. The reason i say this is because of how cold it is by you right now and how thick the fluid is in the transmission. After extended periods of driving, does it seem to get any better?
Don
2002 WS6
RAAEEEVO
Post by RAAEEEVO »
Finally got back to messing with the truck.... traced the problem to a faulty FICM. (low voltage) Replaced... warranty of course ;) and all is well now.
SCGt94
Post by SCGt94 »
awesome man, glad to hear it!
Don
2002 WS6
Return to “Trinity Ford Diesel”
