Do i need to install stock tune!!
bookemdano
Post by bookemdano »
Today i upgraded my revision on my U7191 to (8r08)
Now was i supposed to put the factory back up tune back in the predator
before i did this or not? :oops: 06/GTO/A4....
RE: Do i need to install stock tune!!
before updating the predator, you should restore your original backup to your car first...
if you did not do that, I believe you have now lost your original backup that was saved on the Predator...
Whiterock1
Post by Whiterock1 »
I think if you install a new tune over the Predator tune currently in memory, that (old Predator) tune then becomes your backup. I put stock tune back in before I uploaded the rev. So stock tune remains my backup.
Re: Do i need to install stock tune!!
bookemdano wrote:Today i upgraded my revision on my U7191 to (8r08)
If you did not reatore first, you may need to give me a call to frce the backup.
kttymau
RE: Re: Do i need to install stock tune!!
Post by kttymau »
OK, I think I just made the same mistake. Should have looked @ the forums before I started messing... One thing I did do when I first plugged my Predator to my PC, I was trying to find the right program to perform the update and I was asked if I wanted to back up my "factory tune" to my PC - so I did. Did that help me avert trouble?
By the way, I have an '06 GTO, 6spd, U7191 Predator
No, you need to apply the stock tune to the PCM, not the PC.
If you cannot get the tool to work, give us a call with the tool powered up in the car.
kttymau
Post by kttymau »
Just came back from my car. Plugged in my Predator, everything normal. "Restored to factory back up", car starts, idles as normal. Loaded in "91 octane tune", car starts and idles normal. Serial # displayed on tuner shows the new revision #. can I go out and drive it now with a clear mind, or is it still possible I have ruined something???
You are all good.
kttymau
Post by kttymau »
thanks for the super-quick response!
I have the day off and now I'm headed for Mt. Palomar to rip it up!!! :twisted:
Return to “Predator GM Gas”
