xmodem timeout
xmodem timeout
once plugging by diablo for my 2002 camero u7198 and try to connect to computer i get a XMODEM TIMEOUT. WHat do i do to make it work properly?
RE: xmodem timeout
Can you give us a call at the office with the tool plugged in to the PC.
We'll walk you through the process.
RE: xmodem timeout
I just emailed you some instructions as well...
djsanchez2
RE: xmodem timeout
Same problem here. Email is [email protected]
Unknown303
RE: xmodem timeout
What type of cable are you using to connect, If its the DB9 (Serial) connection then it sounds like you have a null modem cable and need to buy a straight through serial cable. If the Tx and Rx lines are cross neither device will see each other properly.
