2003 CORVETTE LS1 6SPD w/VARARAM VB2, I need tune specs
WJW257
Post by WJW257 »
I have a 03/2003 Corvette cpe 6spd, LS1, 3.45 axle, with a Vararam VB2 CAI - 160degree Hyperstat, 40,000 miles, everyday driver, 12 miles to work, I live in Atl,Ga (hot & humid during spring &summer) no other mods, all else is stock.
I have the DiabloSport Predator U7198 programmer.
I need to know what specs to start with, I ve got most alll the pinging out by adjusting the timing to 1%+ in the mid & upper rpm settings.
I am experimenting with the injector curve at 1-3% + range.
she seems to run fine but what else can I do
before this the car seemed starved for fuel at about 4500 rpm under quick accelleration.
RE: 2003 CORVETTE LS1 6SPD w/VARARAM VB2, I need tune specs
Follow the sticky above to get the LTFTs dialed in and you should be all set.
I am lost as to how you got rid of the pinging by adding timing? That seems backwards to me....
WJW257
Re: RE: 2003 CORVETTE LS1 6SPD w/VARARAM VB2, I need tune sp
Post by WJW257 »
I dont see a sticky, I'm new to this forum.
RE: Re: RE: 2003 CORVETTE LS1 6SPD w/VARARAM VB2, I need tun
stickies are located at the top of the main Predator GM Gas forum listing...
but here's the link for ya' ;)
http://www.diablosport.com/index.php?na ... opic&t=917
Return to “Predator GM Gas”
