7194 for a 2010 Camaro
mzodarg
Post by mzodarg »
Ok- I had a Camaro, originally used a Diablo to tune it with, then I had it put on a dyno. Diablo was return to original config and now I have gotten rid of the vehicke. I purchase a 2009 Avalanche and am wondering since the unit is returned to original config can I send it to Diablo and get it reflashed as a 71?? something or another for the 09 AV or am I going to have to sell this one and Buy another? I hope it is easier than selling one to get another.
Let me know.
Mike
Solid
RE: 7194 for a 2010 Camaro
Post by Solid »
Hello Mike,
If i'm correct you can use the same predator on the 2009 Avalanche aswell! Did you unmarried the predator the correct way? Wat does the screen shows when you select last tune writing? if it says original back up the tool is good to use on the avalanche. But you can try to connect it any ways. Then you can see if it works. Just make sure that the predator is on the right revision!
Goodluck!
Solid
Yes, you can use the U7194 for your 09 Av, just like Solid...
Solid
Post by Solid »
Yes!!! :mrgreen: :mrgreen: :mrgreen: I'm a trough for the next round mike? hahah LOL
mzodarg
Post by mzodarg »
Great! Yes this unit was returned to original, so I should have no problems. Thanks!
yep, you'll be good to go...
the 7194 is the same one for the Avy...
Return to “Predator GM Gas”
