Abuse mode???
Limp1
Abuse mode???
Post by Limp1 »
Did I see something in the Torque Management section of my Predator, (GM04, version 2.10) that said Abuse Mode? Could someone tell me what it is and what it does? Am I using it in my 2004 Vette with the performance tune installed and finally, do I need to use it?? Thanks again guys, my car is running great!! Thanks to all...bob
Torque Management
* TM Abuse Mode time limit:
This is the time in abuse mode as a function of temperature. Turning it off in conjunction with Upshift Torque reduction and %Torque Reduction vs RPM will eliminate torque management.
* %Torque Reduction vs RPM:
Torque reduction as a function of RPM, turning it off in conjunction with TM abuse mode time limit and upshift torque reduction will eliminate torque management.
* Upshift Torque reduction:
Torque reduction control for each individual gear, turning it off in conjunction with TM abuse mode time limit and %Torque Reduction vs RPM will eliminate torque management. However we have noticed that the shift feel when disabling the upshift torque reduction in trucks and SUV's is reduced and therefore recommend leaving it ON for trucks and SUV's.
Thanks Lew!
Limp1
Post by Limp1 »
also, Thanks Monte, you've been a big help to all here....bob.
