2007 Hemi Ram - CMR Trans delete
hemifever
Post by hemifever »
In CMR, what are the steps (if possible) to successfully a delete a trans for this code? 2007 Hemi Ram processor 05094492AK
I've attached a bkup file that includes the trans settings
original-bkup.drg
(70.15 KiB) Downloaded 155 times
ElectricBlueHemi
RE: 2007 Hemi Ram - CMR Trans delete
Post by ElectricBlueHemi »
I know you guys have said this can be done, so I'd really like to know since I plan on going with a 4l80e and manual valvebody in my truck. The 545rfe is ok, but a 4l80e swap would give me much better control on shifts, especially when I install nitrous. I have my 1-2 shift set to 5100 just to complete the shift by 6200 (6200 rev limit). I don't want to bang the rev limiter on nitrous.
ElectricBlueHemi
bump
ElectricBlueHemi
bump for an answer
is this a manual trans file?
auto equipped and TCM equipped are already turned off...
hemifever
Post by hemifever »
no, it's an automatic truck. The Dodge pcm database shows it as :
2007 DR 5.7L ATX 26 GAL FED
The manuals appear to show as an MTX rather than ATX
If the file is a 5spd file and he's got an auto, that may explain his extreme shifting difficulties?
yupper.
that file is not set up for a TCM or an Auto trans.
hemifever
Post by hemifever »
What do we need to do to correct this? What do you need from us (or the customer) ?
Not sure, how did this happen?
Its a factory Auto truck? Was this flashed with one of those 'special' SCT files?
I would think a reflash with the starscan would do the trick.
ElectricBlueHemi
Factory auto truck. I've only used Diablo for tuning. Well, I did use superchips for about a week, but returned it back to stock and everything went back to normal. I ran the diablo 93 tune for a while and then the engine mods came and it's been CMR ever since. How would my trans be shifting then if it's a manual file?
hemifever
Post by hemifever »
Yes, it's a factory auto truck. His pcm sticker is 05094492 (aj) which is what the orig backup is and is what the Diablo tuning is putting back in it (AK). Is it possible the Diablo db has this processor coded incorrectly?
Let us know what to provide to correct this. Johan has been trying to get this to shift correctly for 6 months probably. I hope this is the answer.
Interesting.
I'll have to ask Johan to look into this when he gets in to the office.
ElectricBlueHemi
Found anything yet, or is Johan still out of the office? Haven't seen him post for a while, so he must be out?
ElectricBlueHemi
How about now?
hemifever
Post by hemifever »
any updates on this one?
