I just installed a new Predator/puck combo and I have two problem with it.
1. When reving the truck in neutral or park the RPM's go up and do not come back down, I have to kill the motor before it blows up.
2. I keep getting a permanent trouble code saying PCM not Programmed. Delete it and it keeps coming back.
Both problems happen on any setting.
If anyone could help it would be greatly appreciated.
Problems with Predator
dgparsons2
2004.5 Ram 2500 H.O.
4" turbo back exhaust
AFE Intake
Edge Juice w/ attitude
Predator Power puck combo
Transgo shift kit
Modded CP3
Bd auxillary lift pump
AFE Intake
Transgo shift kit
Modded CP3
RE: Problems with Predator
Try restoring the backup and reinstalling the tune.
- duallydave
when the tuner boots up what version does it say you have?the idle thing could be assoisated with the r28 version.if you have that version update it to the r29 available on this site.what code is it saying you have?there is a code that comes when you use the tuner,i cant remeber what it is but its not a big deal,could be that one that you have.what tune are ya running and how do you llike it?
dgparsons2
The code I keep getting says PCM not programmed. I have already updated to the r29 version.
The problem with reving is with any tune in neutral or park. It takes about 30 to 40 seconds to idle back down and the whole time it is spitting and sputtering. It does not do it when i put it back in stock mode.
AFE Intake
Transgo shift kit
Modded CP3
AFE Intake
Transgo shift kit
Modded CP3
dgparsons2
By the way I am running the extreme rkl puff tune no timing added.
It is ok, but it does not feel as strong as the original extreme predator tune.
AFE Intake
Transgo shift kit
Modded CP3
AFE Intake
Transgo shift kit
Modded CP3
- duallydave
im also running the extreme rkl puff no timing,i love that tune.i think that code is normal,i was asking for what number it is.p-????.i think its p-148 is the normal one,i cant remeber.thats weird about the idle,i havent heard of that using the new r29 file.i had the idle issue with r28.maybe go back to stock and reinstall the r29 and then reinstall the puff tunes then put it in your truck,its alot of work but may help.
- duallydave
also are u using the puck?if so try removing it and see if u still have the isues.of course the extreme with no timing may not feel as responsive as with timing,i think timing adds responsiveness.
dgparsons2
The idleing problem is worse with the puck than without. When you say remove it do you mean take it out completely or just turning it back to stock mode. Because it still does it in stock puck mode.
AFE Intake
Transgo shift kit
Modded CP3
AFE Intake
Transgo shift kit
Modded CP3
