2003 Srt-4 tune
lilkdude87
RE: Re: RE: 2003 Srt-4 tune
agp told me something bout teeing it into the bov/throttle body
Bad idea. The line you would be getting your source from is after the throttle plate. There is vacuum there. The TIP sensor should not see vacuum. Honestly, if I were you I would remove the hard pipe and put the stock one back on. You gain nothing by having that hard pipe.
lilkdude87
well you have to have it in order to go to a bigger turbo so im just gonna tap into the pipe
