2003 Hummer H2
yes it is a old tuner, that i just bought new
i want to say that it has backed up my stock tune, and it shows my VIN # on the predator.
when trying to install teh performance tune tho, i get 2 errors
Required time delay has not expired
scripted error
write failed.
yes i have the onstar and radio fueses pulled
key turned on, not accesories
i have even unplugged teh battery in a attempt to see if it would clear it so i could upload.
now what??
besides the obvious of getting a new updated unit.
U7190 error required time delay has not expired
RE: U7190 error required time delay has not expired
do you have any other aftermarket items installed in the truck, like aftermarket remote start, alarm, satellite radio, trailer brake, stereo amp, in-dash nav system, etc etc??
you need to also disable/disconnect any of those types of items as well, since they create power draws...
those are usually voltage related errors...
well it turns out i havent actually gotten the onstar fuse pulled.
i folled the instructions in the manual, and pulled a few more additional fuses, but it seems the Onstar fuse is actually the fuse labled "Info" int he fuse box. so, when i get off work tonight ill give it a try and hopefully we can call this good.
thanks for the help btw...
