05' Dodge Ram - u7137-9r06 - No more Trans control????
HeLLSPaWN
RE: Re: RE: Re: RE: 05
Post by HeLLSPaWN »
A virus wouldn't do anything to your vehicle.
But if a coder that can disassemble the code, Change settings and reassemble it, could cause severe harm to your vehicle
2005 Dodge Ram 1500 Daytona 4X4
Volant CAI
Predator U7137 w/91 tune
Jet 180 Degree Thermostat
Majefski
Post by Majefski »
Yup, that's why I cautioned in an earlier post on this thread to keep in mind that you are flashing your vehicle computer with this code. Of course, if I knew how to reverse engineer the code, then I would've made my own 9r07 hybrid code with working tranny options already and never would've posted my thread just minutes before the initial post in this one.
Seriously though... I'm nowhere close to smart enough to do that.
I supervise a group of 5 that fixes PC's and servers for 2,000(+/-) people, I'm good at that job. If you put code in front of me though, I run away screaming. You'll find me somewhere in a closet in the fetal position rocking back and forth after looking at code... :)
HeLLSPaWN has a great point though... I know I'm trustworthy, but you guys don't. I know those files are clean and original DS files but how do you know that. Hopefully DS will come through for us soon and not put us in this position again in the future. I would like to suggest that DS keep both the current file and at least one previous version available for DL in case something like this does happen again.
I'm just waiting for the 9r07 to come out, I left 9r06 in for now (because I'm lazy) and because my tranny issue was mostly resolved after having a trans flush. So, I'm leaving well enough alone for now.
2010 Ram HEMI Sport 4x4
Factory dual exhaust
K&N Air Filter
Diablosport Predator tuned
Beltronics RX75 Plus Remote Integrated Radar Detector w/ Laser Shifters.
HeLLSPaWN
Post by HeLLSPaWN »
I reflash with your crom, no problems
Volant CAI
Quick
Re: RE: Re: RE: 05
Post by Quick »
Majefski wrote:None taken... I'm a tech support supervisor for a fortune 500 company tasked with (among other things) network and file security.
oooh, maybe you're the guy I want to talk to :)
running XP Pro. Using Acronis True Image 2010 which I really like. I use the Image backups but not sector by sector (space and I want the individual file access). I would like to do full disk encryption with maybe something like WinMagic's SecureDoc. Single password at login time. Any chance of something like that? Full disk encryption that works with an imaging backup?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Majefski
Post by Majefski »
Way over my head on that one. Though I supervise 2nd and 3rd level for tech support, my group is more like 1st level support (first line of defense) for our encryption tasks. We have an entirely different group for that.
We do use full disk encryption for our client machines, but we don't do any sort of client system backup, only server backups.
I can tell you that if you have an encryption system worth is salt, it's nearly impossible to view files on a different machine that what it was created on (I don't know how you're trying to use your image backups). Usually the key hash is a mix of active directory, MAC address, and OS info. Otherwise, you could just steal a drive or NV memory even, slave it to another machine and take the data, effectively defeating the whole purpose of encrypting it to begin with. There are just too many possible environment scenarios that I don't fully understand to really answer this for you... Sorry.
Man... I was trying not to think about IT stuff this weekend...!
Okay, we're way off topic now... Don't want this to get bumped... I think DS will answer this post before mine due to the amount of posts...
Send me a PM if I can help any more.
K&N Air Filter
motorscooter
Post by motorscooter »
any update on this :idea:
all the good stuff.
gergregg
Post by gergregg »
:punisher:
Hoping to have a fix this week guys.
truckin
Post by truckin »
Fingers crossed
HeLLSPaWN
Post by HeLLSPaWN »
Could you double check the 05 Ram Hemi quick adjusts also and make sure what should be there is there, I am missing Adjustment that I was told are supposed to be there
Volant CAI
truckin
Post by truckin »
Which ones are you missing?
HeLLSPaWN
Post by HeLLSPaWN »
Fan Speed is the one I need, I put in a 180 Degree
Knock Sensor is missing also
Volant CAI
Re: RE: Re: RE: Re: RE: 05
HeLLSPaWN wrote:Fan Speed is the one I need, I put in a 180 Degree
There is no Knock sensor parameter? (never was...)
Also, dont these trucks use mechanical fans?
gergregg
Post by gergregg »
Yes they use mechanical fans.
HeLLSPaWN
RE: Re: RE: Re: RE: Re: RE: 05
Post by HeLLSPaWN »
So I installed the Thermostat For Nothing?
Volant CAI
