Problems with u7194
nofinga911
Problems with u7194
Post by nofinga911 »
Hi first, when I record a log in my truck (07 escalade ext) it only lasts for a coupld of minutes until the log is full. Second, when i view the log when my WOT (throttle is at 100%), it's showing my Air/Fuel Ratio to be 18.32!! Those numbers should be in the 12's...??
RE: Problems with u7194
Yes, it seems there is an issue with the way the A/F is displayed in the tool.
I have been told by another user that the correct value is displayed in the DAT Viewer software, try looking at it there.
hey Mike... yeah, I just checked out his log for him... it's also only logging for 1 and a half minutes... and he only had my 7 parameters logged... is this like the same thing with the one for the Vettes - where they have very short logs also??
Re: RE: Problems with u7194
06MonteSS wrote:hey Mike... yeah, I just checked out his log for him... it's also only logging for 1 and a half minutes... and he only had my 7 parameters logged... is this like the same thing with the one for the Vettes - where they have very short logs also??
Yes, i believe it is an issue with the U7194 tool.
They are looking into this as well.
here's the log...
Avi-Dubz-log1.zip
(52.45 KiB) Downloaded 119 times
RE: Re: RE: Problems with u7194
Does the tool display the correct value in the logs, or is it wrong as well?
I just discussed this with John C. and he said that when logging with the U7194 if you stream the data to a laptop you will have unlimited log time.
the dataviewer shows it correctly, but when exported to csv file, it's wrong in there...
WAIT - HANG ON!!
k... found the bug.... it's with Dataviewer 3.1....
dataviewer 3.0 shows everything correct - AFR at WOT is 11.9x to 12.xx, and exports the csv file correctly as well.
HOWEVER...
dataviewer 3.1 is showing the wrong AFR - it goes up to 18.xxx - both in the dataviewer app and the csv file as well.
Return to “Predator GM Gas”
