METRIC SYSTEM
General Trinity Support
johndiesel
METRIC SYSTEM
Post by johndiesel »
I am in Australia and we use the metric system.
Is the Trinity configured so that it can be set up to give metric readings
will need this for virtual drag tree and gauge monitor.
RE: METRIC SYSTEM
All gauges in Trinity can be converted to C from F or KPH from MPH through the logging menu by selecting convert units.
moh050
RE: METRIC SYSTEM
Post by moh050 »
i cant find logging menu??
RE: METRIC SYSTEM
right on the main screen of the trinity... lower right... says "Logging"
heh...
moh050
RE: METRIC SYSTEM
Post by moh050 »
ok i find the logging but there is add gages and remove it where is convert units.
jimb
RE: METRIC SYSTEM
Post by jimb »
Add a guage for the desired parameter (e.g. Vehichle speed); Then select the actual gauge and "Change Display Units" is available.
EssentialJuice
RE: METRIC SYSTEM
Post by EssentialJuice »
can you change from metric to standard for gauge readings? such as synth gauges and others?
2004 f350ps
4" tb cat delete
gizmodo
RE: METRIC SYSTEM
Post by gizmodo »
Yes, select the gauge on the logging screen and hit change units.
EssentialJuice
RE: METRIC SYSTEM
are we both talking about the trinity monitoring screen? like the synth on monitoring screen is boost kPa. can it be changed to psi?
thank you.
2004 f350ps
4" tb cat delete
RE: METRIC SYSTEM
yes, it can.
DrDax
RE: METRIC SYSTEM
Post by DrDax »
Being in the UK we use metric and imperial lol.
Any temp gauge defaults to deg F and I like to work in Deg C easy to change over. edit gauge and change units. Simples.
Return to “General Trinity”
