Quick Wheel Question
nofinga911
ok i plugged my predator into my truck...then modified my tire and rim info...but how come when i went back to check and make sure my wheel and tire info was still there, it reset back to what was originally there as if i didnt modify it...now i installed the tune after i modified the wheel and rim info but i dont know if it got programmed in...
nofinga911
nofinga911
What year is the truck?
Did you enter the factory tire size first, followed by the actual (new) tire size?
nofinga911
its an 07' escalade ext....i entered the aftermarket tire size and then prog. my truck....you mean first program it with the stock and then program it with the aftermarket? i dont understand?mikel wrote:What year is the truck?
OK, thats why I asked...on the 07 trucks, you do not need to enter the stock tire size.
I do recall that one of the older revisions had an issue with adjusting the tire size properly.
Make sure the tool is on the latest revision.
nofinga911
ok i will check it now...but to make sure i am doing everything correctly...i plug in the predator adjust the wheel size (not by tire size) but by the first option that asks for the 2 measurements and then i install the tune...correct?mikel wrote:OK, thats why I asked...on the 07 trucks, you do not need to enter the stock tire size.
