im a newbie where and have a 06 dodge ram hemi. i have the canned 93 tune installed with mds off. i know that the shift firmness option isnt available right now but can someone explain what the other tranny options mean. the 1-2 2-3 and so on. im not sure what they do exactly. any suggestions on what they should changed to for a stock hemi with single to dual exhuast installed, and cold air intake with 93 octane. also any suggestions on any changes i should try with the wot calibrations. like i said im a newbie and not sure what these changes would do and how they would affect the truck
thanks
help with meaning of shift points
You get to set the RPM at which you can get a 1-2 and 2-3 up shift at part throttle (not at WOT). The real flexible part of it is that it will respond to the % of throttle input, depending on how you set it. Notice you can set the RPM at which you want your vehicle to shift with respect to several % throttle inputs. The purpose obviously is to have the vehicle hold on to either first or second gear longer at part throttle, and you can program the shift point depending on how much throttle you are giving the vehicle.
2006 300C-SRT
Mopar CAI/Toyo 245/275 Stagger
185 T-Stat/Catch Can
DiabloToona CMR Gas tune
Extra "Flex" E-85 tune
searles_400
bighemitex
start experimenting and seeing what feels right to your style of driving
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
