EGT PROBE PLACEMENT
KeithStark
EGT PROBE PLACEMENT
Post by KeithStark »
WHAT LOCATION SHOULD THE PROBE BE PLACED?
ropnjessi
Re: EGT PROBE PLACEMENT
Post by ropnjessi »
KeithStark wrote:WHAT LOCATION SHOULD THE PROBE BE PLACED?
See attached.
EGT Gauge Install.pdf
(3.77 MiB) Downloaded 217 times
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
KeithStark
RE: Re: EGT PROBE PLACEMENT
Thanks that will be a big help. I was going to weld a bung in exhaust pipe. this will be much easier.
thanks again
ropnjessi
Post by ropnjessi »
When I drilled mine out I had a shop vac running right at the tap to reduce any metal filings that might fall in the hole. Once the hole was drilled out I taped a straw to the end of the shop vac and stuck it in the hole in the manifold to get what ever could be in there. Some guys use grease when they tap, which helps containing the filings from falling inside to...
KeithStark
Thanks for the info let you know how it all works out
KeithStark
well got all gauges installed and pillar pod, EGT,Trans temp, Boost. Installed Transgo shift kit( really nice) but what a job but it was well worth the effort. I had quadzilla towing module that i removed,hooked up predator and installed performance tune it seems to be stronger @ 1800 up weaker 1400-1800 RPM. Have not tried tow tunes but will try tomorrow. one question can I still use the quadzilla tow module with nthe predator and if so how?
