Question about a used Predator I want to buy
Pharmer81
Post by Pharmer81 »
I'm thinking about buying a used tuner for my 99 FRC vette from a guy that used it on his procharged vette. It came from Procharger with his blower setup, so I assume it came with a custom tune loaded to it specific for that setup. It is currently unlocked. The part # is pc7198, version: v.9r01, Hardware: Univ_Rev2. My question is will this tuner only have the custom tune from Procharger on it, or will it still have the stock diablosport tunes in it? If they are not in it, can I download the revision 9r15 for the u7198 and then basically have a stock diablosport u7198 at that point? I just want to make sure this will work for my car before I buy it. Thanks.
RE: Question about a used Predator I want to buy
It only has the ProCharger tunes and won't work without one. You also cannot update it to non-supercharged tunes, so if you aren't buying the whole blower kit, its useless to you.
You can load up to 5 custom tunes from a CMR dealer to it.....
Return to “General Support”
