05' Dodge Ram - u7137-9r06 - No more Trans control????
HeLLSPaWN
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE:
Post by HeLLSPaWN »
Needing to pay $99 does not sound right.
I paid $375 For My Predator, it started out as a U9000 so if it is a hardware issue then all the predators should be F'ed up.
What exactly is the limitation that makes the predator not able to read/write the TCM?
Is there anyway to make the predator open source or make the croms viewable outside the predator?
2005 Dodge Ram 1500 Daytona 4X4
Volant CAI
Predator U7137 w/91 tune
Jet 180 Degree Thermostat
truckin
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re:
Post by truckin »
HeLLSPaWN wrote: What exactly is the limitation that makes the predator not able to read/write the TCM?
Thats what Im curious about too, I mean the 9r05 writes to the TCM with no problems, so does the 9r04 so why would the unit itself be f'd up if both the CROM releases prior to this one worked fine and wrote to the TCM.
With the 9r06 CROM as well as the other the options prior to actually loading the tune onto the vehicle doesn't even show the trans support, hell when it first reads the vehicle it doesn't even read the TCM. But going from those CROM's back to older CROM's and everything reads perfectly.
silverdaytona
Post by silverdaytona »
I have been having the same problem with the tcm not being read for the 9r06,so I went back to 9r05 and it works fine. Mike will you send me the fix so I can try it on my 2005? Thanks
truckin
Post by truckin »
bump
truckin
Post by truckin »
Guys who got the email sent to them last week, POST UP if it is working for you or not and if you have the tcm calid or not.
So far its a no on both for me and hellspawn. Who else has tried it out?
motorscooter
Post by motorscooter »
sounds like silverdaytona can be add to the list. GUYS they can't fix this if you don't speak up.
all the good stuff.
glass3222
Post by glass3222 »
I recently got a DSP for my 05 ram. It came with 9r04 installed. I have been running it and debating on whether or not to update it to the 9r06. I have been reading about these issues with the 9r06, so should I update or stay with the 9r04. What will I gain if I upgrade. It seems like I may loose my TCM control. What should I do?
glass3222
Post by glass3222 »
Ok. I was talking with someone on another forum. I decided to update to the 9r06 crom, since the person I was talking to can email me the old crom if I want to go back.
Well I downloaded it and just got done installing it in my 05 ram.
It reads the TCM and writes to it during install. However I have no trans options anymore.
I do have both PCM and TCM CALIDs
I also gained throttle sensitivity adjustment (might be a good thing, I'll have to mess with it) and MDS adjustment (I have an 05 with NO MDS)
So I guess add me to the list of no trans adjustments???
Majefski
Post by Majefski »
Ok, I have the 9r07b tune in my Ram. Unless I'm missing something, I think everything worked well for me. I don't have the tool plugged into the truck, but when I supply power it shows last tune written was 93 perf. The truck seems to be responding well, and I was able to modify trans controls. I had everything from throttle sensitivity and MDS on the engine side to LP settings and shift point RPMs on the trans side. The truck seems to have a smoother tune now. What I mean is... it doesn't try to rip my head off if I'm cruising at low RPMs when it decides to shift, but if I let it shift at full throttle, it'll go sideways when it firmly hits second gear. Much smoother and more comfortable for passengers than I had before.
So, am I missing something...?
2010 Ram HEMI Sport 4x4
Factory dual exhaust
K&N Air Filter
Diablosport Predator tuned
Beltronics RX75 Plus Remote Integrated Radar Detector w/ Laser Shifters.
truckin
Post by truckin »
So yours read the trans? Mine didn't read it on either of the tunes, or show a calid. I wonder if it is a problem with the tuners that started out as a U9000 then...
mrs.esterhouse
Post by mrs.esterhouse »
No change in mine, between 9r06 and 9t07b, no tcm calid and no transmission control. Just going to reload 9r05 and wait to see what comes out here. Feel free to email any further revisions that you come up with.
2005 ram hemi :crashing:
Majefski
Post by Majefski »
Hmm... I'll plug it in in the morning and see if I can change anything in the trans. I made the changes in the tool before actually installing the tune in the truck. Maybe it didn't make the changes and I just thought it did. It definitely tuned the trans, but I don't know for sure if it took the mods I set for it, or if it ignored them and just used the canned tune. I'll post whatever I find within the next few days, tomorrow if I can find the time. I gotta try to figure out if there's a trans setting I can change that I will notice the difference. Maybe a downshift RPM setting.
K&N Air Filter
luckydt
Post by luckydt »
Majefski i see you say you have the 9r07b crom where did you get this? Right now the site only has u7137-9r06.crom (2574k). And to diablo what are the changes between the two?
2006 Dodge Ram Laramie 4x4 5.7 Hemi
6" suspension lift
20" rockstars with 35" tires
K&N cold air intake
Dynomax dual exhaust
Diablo Sport predator U7137
180 Thermostat
long tube headers
Y-pipe
85mm TB
HeLLSPaWN
u7137-9t07b_export.crom
Post by HeLLSPaWN »
Here is the latest crom. I don't know if they care that I upload it if not they will remove it.
I didn't modify it, in anyway & of course I am not responsible if your vehicle gets upf'3
Remember to restore your vehicles stock PCM/TCM before updating your predator
(2.46 MiB) Downloaded 295 times
Volant CAI
truckin
Post by truckin »
mikel - Quick question, is there any difference in the tuners between the ones that started out as a U9000 that were then converted into a U7137 vs the ones that came as a U7137? Just wondering if that is the issue?
