What diablo chip do i need
mydream
Post by mydream »
Hi
I'm building a Factory Five roadster and i have installed a 2000 mustang GT 4.6 SOHC.
I have all of required items but i'm having problems with PATS.
I have been told that you have a chip that removes PATS. If so, wich one do i need, and does it give the engine any performance. Also, if the chip is installed, i would like to wire diet the harness...does this chip also able to remove the GEM module.
Thierry
kmac1
RE: What diablo chip do i need
Post by kmac1 »
Thierry, You can use a chip or a Predator to resolve these issues. GEM module is not needed. See our Dealer Locator for the CMR dealer closest to you and they should have no trouble at all setting you up with a performance file that has the PATS shut off.
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
mydream
Tech support
Post by mydream »
HI
I finally got my engine running. I thought it was PATS related but ended up being 8 seized injectors. (engine sitting for a long time)
I started my wire diet, removed all GEM module and wiring and now i would like to remove my PATS. I have followed your suggestion and contacted 3 local retailers of your product here in Canada, wich all have no clue what i'm talking about, or not knowledgeable enough about your product.
Again, i'm building a Factory five Roadster, i'm doing a wire diet, i would like to remove PATS, traction control, maybe rear 02 sensor (if you recommend i do).
Can you tell me exactly what i need, where to buy it so i can get support after.
The supplier i spoke with ,told they can sell me the unit, but to deal with you for the rest ???.
I f i buy a used unit, can that be any good, can it be used, i can get one for a fair price.
I wont pay over 500$cnd for a unit that i can't get any local tech support.
I have a 2000 Mustang GT SOHC 5 speed Donor
Thank you
Thierry
mydream
RE: Tech support
Post by mydream »
HI
Can anyone help me please?
I would need to know, if i order a new unit a new unit from the states or buy a used one here in Canada if i need to pay for additional support to do a tune, like removing Pats. I have contacted local shops and they are unable to give me clear answer. They have suggested contacting Diablo
Thank you
Thierry
RE: Tech support
Yes, a custom tune is required to disable PATS.
Where are you located?
Do you know Chag Autosport?
Brown Brothers Ford?
mydream
RE: Tech support
Post by mydream »
Hi Mike
I don't know any of these guys, but Chag Autosport is close enough to my place. Are they well experienced?
I'm located in Vaudreuil Quebec. J7V 9J8
Thierry
RE: Tech support
Yes, Chag is more than qualified....Sebastien will get you going in the right direction.
Tell him I sent you.
karlmeyerholt
RE: Tech support
Post by karlmeyerholt »
i have a 2004 jeep wrangler with 4.o i6 what programmer would i use to program ecm on truck
Re: RE: Tech support
karlmeyerholt wrote:i have a 2004 jeep wrangler with 4.o i6 what programmer would i use to program ecm on truck
there's no support for that at this time...
karlmeyerholt
RE: Re: RE: Tech support
is their any one i can talk to to setup experimenting with my jeep please email me at [email protected]
Return to “General Support”
