Crimson wrote:The above instructions were only if you running vista 64bit, to find out right click on my computer and then properties look for "system type" this will say either 64-bit or 32 (x86) bit.
Your connection is serial to usb right?
Again, if your system is 64bit os run the DRemover_x64.exe this should remove the driver.
1) Press f8, start without driver signature enforcement
2) Run the dremover_x64 (where you uncompressed the driver)
3) Connect the DS to the ac adapter (power up the predator)
4) Connect the predator to the computer
5) Vista should say found new hardware (if it doesn’t then something else is wrong)
6) If it does detect it "install the hardware I manually select...(advanced)
7) Point to the location of where the drivers are
If it says these drivers are not digitally signed continue anyway? say YES
I could probably fix this remotely but I would charge you
Make sure the predator is powered up and try another usb port.
thank you very much it worked that was very fustrating me
