I was reading in a 'customer interest' service bulletin for my truck and came across this article:
Bulletin No.: 06-06-01-010A
Date: February 04, 2008
INFORMATION
Subject:
Information on Close-Coupled Converter and Engine Breakdown or Non-Function Due to Severe Overheat or Lack of Oil Causing Piston(s) Connecting Rod(s) Crankshaft Cylinder(s) and/or Head(s) Camshaft(s) Intake and/or Exhaust Valve(s) Main and/or Rod Bearing(s) Damage
Models:
2004-2008 GM Passenger Cars and Trucks
with Close-Coupled Catalytic Converters
Supercede:
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 06-06-01-010 (Section 06 - Engine/Propulsion System).
Certain 2004-2008 General Motors products may be equipped with a new style of catalytic converter technically known as the close-coupled catalytic converter providing quick catalyst warm-up resulting in lower tail pipe emissions earlier in the vehicle operating cycle.
If an engine breakdown or non-function were to occur (such as broken intake/exhaust valve or piston) debris may be deposited in the converter through engine exhaust ports. If the engine is non-functioning due to a severe overheat event damage to the ceramic "brick" internal to the catalytic converter may occur. This may result in ceramic debris being drawn into the engine through the cylinder head exhaust ports.
If a replacement engine is installed in either of these instances the replacement engine may fail due to the debris being introduced into the combustion chambers when started.
When replacing an engine for a breakdown or non-function an inspection of the catalytic converters and ALL transferred components (such as exhaust/intake manifolds) should be performed. Any debris found should be removed. In cases of engine failure due to severe overheat dealers should also inspect each catalytic converter for signs of melting or cracking of the ceramic "brick". If damage is observed the converter should be replaced.
My question regarding this is that, since I am unfortunatly living in California for the time being, should I make any other adjustments so I don't damage the material inside the cats? As soon as I can get out of this state I will "fix" that catalytic converter issue.
2004-up GM trucks/SUVs cats
- pelicandivebomb
Post by pelicandivebomb »
2008 Silverado vortecmax z71: vararam intake, jba headers, true duals with X-pipe and two Dynomax VT mufflers
Jump to
- Welcome to DiabloSport
- ↳ Announcements
- ↳ Test Vehicles Wanted
- i2/i3 Technical discussion
- ↳ i2/i3 for Dodge, Chrysler, Jeep and Ram
- ↳ i2/i3 for Ford vehicles
- ↳ i2/i3 for GM vehicles
- ↳ Ignition updater
- Trinity 2
- ↳ T2 for Dodge/Chrysler/Jeep/Ram
- ↳ T2 for Ford
- ↳ T2 for GM
- ↳ Trinity MX monitor
- PredatorX
- ↳ PredatorX for GM vehicles
- ↳ PredatorX for Dodge/Ram vehicles
- ↳ PredatorX for Ford vehicles
- ↳ PredatorX Requests and Feedback
- Predator 2 Support
- ↳ Predator 2 for Chrysler/Dodge/Jeep/Ram
- ↳ Predator 2 for GM
- ↳ Predator 2 for Ford
- Pulsar
- ↳ Pulsar for Ram
- Trinity Technical Discussion
- ↳ General Trinity
- ↳ Trinity Ford Gas
- ↳ Trinity Ford Diesel
- ↳ Trinity Dodge Gas
- ↳ Trinity Dodge Diesel
- ↳ Trinity GM Gas
- ↳ Trinity GM Diesel
- inTune i-1000 Technical Discussion
- ↳ General inTune forum
- ↳ Auto Updater/PC related issues
- ↳ Mac/Non Windows based issues
- ↳ inTune DCX (i-1000-DCX)
- (Legacy) Predator Technical Discussion
- ↳ Predator Ford Gas
- ↳ Predator Ford Diesel
- ↳ Predator Dodge Gas
- ↳ Predator Dodge Diesel
- ↳ Predator GM Gas
- ↳ Predator GM Diesel
- General Technical Support
- ↳ DataViewer/DV2
- ↳ General Support
- ↳ Custom Tune Support
- ↳ DeltaChip
- ↳ MAF.i.a
- ↳ DSDL
- ↳ PowerPuck/Extreme PowerPuck
- ↳ CatchCan Support
- DiabloSport Community
- ↳ General Questions
- ↳ Lounge
- ↳ Suggestion Box
- ↳ Future Product Requests
