Mike, need map for U1792 & Hummer H2
tomp
Post by tomp »
Hi Mike,
Can you get me 87 Tune & Performance Tune maps to use with Long Tubes for U1792 & Hummer H2? I'd really appreciate it if you would email them to me at [email protected]
Please let me know how to get these into the tuner? Which cable I need, sofware or instructions etc. Thanks Mike!!!
RE: Mike, need map for U1792 & Hummer H2
I'll need a copy of your backup file first.
I am emailing you the instructions.
tomp
Post by tomp »
Thanks Mike, I got your email. One question though, the file you are asking for - is this the original OEM file or a backup of my current modified file I loaded into the ECM using the tuner?
Copy of the backup file from the Predator. (OEM tune)
tomp
Post by tomp »
Hi Mike, finally found the serial cable and power adapter to get this file uploaded to PC. I am replying to you email with a copy of my backup file. Thanks Mike!!!!!!!!!!
Tunes have been sent already.
tomp
Post by tomp »
Wow, that was quick! Thx Mike!
Quick question though...I just read the darn doc you sent to download the file to PC. It seemed so easy that I didn't bother to read it until now. Question is, in Section that says "Note: Before uploading the tune to PC the following step must be performed", what is this step actaully doing? I didn't do this step, prior to sending you my OEM file, but this does not sound like something I needed to do. Am I correct in my assumption here?
tomp
Post by tomp »
Mike, also please help me understand something: why are the changes you make done to the OEM file and not one of the Diablo files? Just curious and want to udnerstand, thanks
Return to “Predator GM Gas”
