05 duramax fault
beck
05 duramax fault
Post by beck »
I have an 05 Duramax with a modified stock air box {cut an opening on side and insulated, per diesel page article.}I am using K&N OEM replacement filter.I have a MBRP 4 in. SS catback exhaust, and your U7185 programer. The first time I tried the 100 hp mode the engine hesitaded had a intake fault and had only two or three gears with the Allison. I reset to stock and AOK.
Steve
RE: 05 duramax fault
What codes did the truck throw?
Have you tried any of the lower powered tunes?
beck
Post by beck »
Sorry, I forgot the codes ,I remember an intake fault. I have had good success with the 65 HP setting.The 100 HP episode is similar to a couple other 05 posts where the engine "pops" dies , but mine restricted full use of the tranny.
Was it a P0101? Is this a Californi vehicle?
Unknown303
Post by Unknown303 »
Code: P0101
Modules: ECM, PCM
Description: Mass Air Flow (MAF) Sensor Performance
lccmo
Re: 05 duramax fault
Post by lccmo »
beck wrote:I have an 05 Duramax with a modified stock air box {cut an opening on side and insulated, per diesel page article.}I am using K&N OEM replacement filter.I have a MBRP 4 in. SS catback exhaust, and your U7185 programer. The first time I tried the 100 hp mode the engine hesitaded had a intake fault and had only two or three gears with the Allison. I reset to stock and AOK.
Steve
Sounds like you limped the transmission
RE: Re: 05 duramax fault
Is this a California truck?
