Lew! Question regarding DiabLew tune.
Poetique
Post by Poetique »
After reading that "Diablew Tune Kill" thread (I think that's it) it's made me want to go ahead and make the jump (not to mention I'm not sure if I still want to Cam & Head by now 4 year old truck, which is why I was waiting in the first place...)
Anywho, few issues.
1. My U7194 is apparently a relic thanks to whatever they decided to change to make the "old" U7194 (2 years and a few months ain't that friggin old imo...) a doorstop. Hence, I'm assuming I'll never be able to update my Predator again. Unless of course I decide to pay $100 for it to be upgraded, which is highly unlikely. Will this pose a problem?
2. My Predator has an odd problem that I still havn't 100% remedied. You may recall the thread I made about how my Predator couldn't recognize my truck and I had disappearing options when it did. I've narrowed the problem down to the cable, but there seems to be little I can do about it. Just holding the cable into the part where it goes into the Predator works well enough for installing tunes, but apparently isn't stable enough for logging. Of course there could be another problem I'm entirely unaware of, because if the whole problem was cable instability I feel as if it wouldn't let me fully install a tune either; then again, I can't use both hands to steady the Predator while driving & logging... but I'm uncertain either way. Anywho...
I can tell it to watch & record a log, and even watch it as it logs. It also eventually says the log is full. But what I've come to find is that it doesn't actually save the log.
I've tried to pull and save two logs from it now with no success. On the first attempt it wouldn't leg me pull the log at all. On the second attempt it let me pull and save the log, but it only seemed to actually record the logging intervals and not the parameters themselves...
Now, seeing as it does always at least log, I was wondering if you think it should still be able to record to a PC if I bring my laptop along and just let the log run through to the PC.
If so, how exactly would I go about setting it up to do so?
Of course all that's irrelevant if the answer to #1 makes this a pointless venture entirely :?
RE: Lew! Question regarding DiabLew tune.
#1 - nope, you're perfectly fine with that version 7194 predator you have... no worries...
but #2... that's an issue... sounds like that predator needs to be repaired man... that ain't good...
yeah, if you can keep the connection/cord steady so that it can access the obd port, you should be able to use the laptop and dataviewer program to record/save logs...
Poetique
Post by Poetique »
Yeah I might just go ahead and pop it apart and try to fix it myself. If a simple update is $100 I'm afraid of a repair.
I imagine it's probably just a wire that needs re-soldering.
GMC-6.2
Post by GMC-6.2 »
U won't regret getting the lew tune man. Trucks nasty now. Lew is the man.
2009 GMC Sierra 2wd, 6.2L vortec. AFE cai, Magnaflow muffler dumped. Diablosport predator..........runs like a scalded dog.
you beat that Challenger yet GMC????
heh...
GMC-6.2
Post by GMC-6.2 »
the kid didnt come to town. im waiting for it tho. and will have 2 logs coming ur way soon.
tdub09
Post by tdub09 »
MAN LEW tunes are great!! he finished my first WOT log and i put it on the truck and from a 45 roll on freeway a LS1 trans am with at least exhaust and intake i jumped him and beat him to bout 105 or 110 and then he starts creepn up SLOWLY!!!!! and i beat a LS1 C5 all stock yes, from and stop in bout a quater mile but that was before i ever had a predator at all!!! i would hate to see that guy again and really pull away from him!!! GO WITH THE DIABLEW TUNE!!!!!!!!
2009 GMC
to much to list
U7194 DIABLEW TUNED
"THERES NO REPLACEMENT FOR DISPLACEMENT"
Poetique
Post by Poetique »
Alrighty. Now if I can get a good temperature day to try to get it to log properly I should be golden. But the way the temperatures are around here, I wouldn't expect a decent logging temperature till April lol.
hahaha... that's fine man... I ain't goin' nowhere ;)
whenever you can do it, and do it right... heh...
Return to “Predator GM Gas”
