need help
500hp
need help
Post by 500hp »
helo,need help for hemi 6.1.i insanlled 93 tune on 300c how do i change shifts what screen do i go under?my new predator didnt come with directions i dont want to make a mistake.i was able to up date car via down load from computer.thank you and car does not have cold intake howe much hp would i get adding cold air intake,what is best brand for these cars.
RE: need help
Shift points are under quick adjusts for these cars...
500hp
RE: need help
Post by 500hp »
thank you for info.i found info in the pdf file . one ? r shifts it has modemode2 mode3 used mode 1 not sure what th ese modes do thank you for help.this tool is awesome,thank you mike.
slickrock
RE: need help
Post by slickrock »
I need some help, I hope someone can help me. I have a n 04 cummins. I already had to replace a piston, injector, re-man the head, dropped a valve seat from too much heat, guess. Now I have the truck back and I want to put a power puck on it. I drove it around and seems like no problems, then I go to start it and just cranks and cranks. So I took the puck off, runs fine now. What is wrong?
slickrock is online now Report Post Edit/Delete Message
Return to “General Questions”
