05' Dodge Ram - u7137-9r06 - No more Trans control????
truckin
Post by truckin »
Alright went out and reloaded the 9t07b CROM on my truck to run the test.
9r05 CROM CALID's
PCM: 56028958AI
TCM: 05094258AD
9t07b CROM (Pulled with the key on prior to plugging in predator)
PCM: 5602895AI
TCM: NONE
motorscooter
Post by motorscooter »
we getting any where on a cure for this.
all the good stuff.
truckin
Post by truckin »
bump
truckin wrote:Alright went out and reloaded the 9t07b CROM on my truck to run the test.
9r05 CROM CALID's
PCM: 56028958AI
TCM: 05094258AD
PCM: 5602895AI
TCM: NONE
Thank you.
Should have a new update Wednesday.
truckin
Post by truckin »
Sweet! Thank you
motorscooter
thanks Mikel
all the good stuff.
white_lightning
Post by white_lightning »
mikel wrote: Should have a new update Wednesday.
will the update have throttle sensitivity adjustments for '05 Hemi Rams?
this info may be too late to do much good, but:
last night I loaded the production 9r06, and an option to adjust throttle sensitivity was in the "modify tune" list with rev limit, speed limit, tire size, wot spark & wot fuel. no trans shift point adjustments though. forgot to check tcm/pcm i.d. with this crom installed. did not load a tune with this crom, I want higher shift points than stock.
loaded beta crom 9t06d and there was no throttle sensitivity adjustment, but trans shift point adjustments were back. loaded 93 tune + altered shifts, then custom pcm tune and everything works. shifts are where I set them, custom tune loaded.
maybe this is wishful thinking, but shifts seem a bit firmer with 9t06d than with 9r04. my truck also seems to feel a little smoother more powerful. seems to rev faster. I set WOT shifts for 6,200 rpm like before with9r04, but the tach was going to 6,400 instead of 6,200 like it did with 9r04. need to do a datalog & compare it to previous WOT 6,200 rpm shift logs.
since '05's seem to have some peculiar quirks, would it be a good idea to develop an '05 only crom with all the neat adjustments for us '05 owners?
having watched Superchips have many headaches with one-size-fits-all databases, it seems logical to pick years with similar pcm/tcm and set up different croms for each group? a crom for '03-'05, a crom for '06-'08 and a crom for '09-'10?? what do you think?
my truck:
2005 5.7 Ram 1500
PCM: 56028958AI
TCM: 05094258AD
truckin
Post by truckin »
my truck:
2005 5.7 Ram 1500
PCM: 56028958AI
TCM: 05094258AD
My truck has the 9t07b on it now and has the throttle sensitivity settings, also had it on the 9r06 too.
truckin
Post by truckin »
9r05 CROM CALID's
PCM: 56028958AI
TCM: 05094258AD
PCM: 5602895AI
TCM: NONE
Thank you.
So how is it looking? Do you think you'll be able to get the update out today?
thats the plan as of right now...
truckin
Post by truckin »
So tomorrow hopefully?
Please try this crom and report back asap!
u7137-9t07c_export.crom
(2.74 MiB) Downloaded 259 times
truckin
Post by truckin »
will do as soon as i get off this afternoon
dang, I was hoping to release this before the end of the day!!!
truckin
Post by truckin »
Still no good, no trans options and no TCM CALID (key on when checking) everything else seems to work though.
One thing I did notice (and maybe it is part of the problem) when I am loading the CROM file, when it gets to part 3 of the install it only gets about halfway through before it says it is done installing.
