2010 Camaro SS Speed Limiter (How to remove?)
ODB720 wrote:
06MonteSS wrote:here ya go... . use the same custom tune import instructions above that I listed in a previous post...
HEY LEW APPRECIATE YOUR HELP, B-4 LOADING THIS TUNE I JUST WANTED TO KNOW IS THIS THE SAME DIABLO TUNE I SENT YOU OR DO I HAVE TO GO BACK THRU DOING DATA LOGS AND FUEL ADJUSTMENTS AGAIN. OR DID YOU JUST ADD THE SPPED LIMITER CHANGES ? THANKS LEW
same diablo tune with your previous changes man...
I just modified the "last tune written" file and made the speed limit changes...
when you go to install it to your car:
** IMPORTANT NOTE: your Predator/Trinity may prompt you to say that you are changing tunes, and then ask you if you want to "Reset All Parameters?" - make sure you answer/select YES to this question to reset the parameters that you adjusted before. The changes you made yourself before are already in the custom tune, since you copied it out of your car ("last tune written) to send to the tuner. If you select NO, then it will apply your previous adjustments on top of the adjustments that are already in the tune, and it will get ugly. So, if/when it asks you to "Reset all parameters?" - make SURE that you answer/select YES!
You can also still modify the custom tune just like any of the performance tunes.
Do the install just like any other performance tune, and you're good to go with your new custom tune.
wolf13_69
Post by wolf13_69 »
no i didnt disable nothing and the care had adiquate time to cool down between pulls at least 20-30 minutes to nulify this problem. untill the last pull we let it cool for longer to get the 411 pull
SIERRA_BOI
Post by SIERRA_BOI »
This is funny as hell how all the Camaro guys have run past 150 mph lololololol...
Hey LEW, my Zr-1 hit a speed limiter at 199 last night, can you raise it for me? hahahahahahaha....
You guys have some badass cars!
yeah man, I'll set yours to 265 for ya...
:lol: :lol:
RedJewel2SS
Post by RedJewel2SS »
anyone know of a place i can bolt on some wings so i can go flying in my camaro???
just put your arm out the drivers-side window, and have your passenger put their arm out the other window...
:lol: :lol:
ednis187
Post by ednis187 »
Hey Guys, Im from Germany and i have the same Proplem as you all.
I Try it min. 6 times ago and The limiter ist not off.
I drive a 2010 Camaro 2SS L99
I want drive the 91 Oktan Tune without Speelimit
Can you help me please :?
I dont know what to do?
need to connect your predator to your pc, use the dsdownloader app, and export your two tune files and post them up here...
Saving the original backup tune and current tune (Last Tune Written) to your PC:
1. Make sure you have installed the latest version of the DSDownloader app on your PC.
2. Connect your Predator/Trinity to your PC and power it up, and then run the DSDownloader program.
3. Once you open DSDownloader, click "Options" and make sure there is a check mark next to "Auto Connect".
4. Once Auto Connect is enabled, the DSDL will search for and find your Predator/Trinity on its assigned COM port.
5. Once it finds your Predator/Trinity, you will be taken to the Express Tune page. From here, click "Get tune file from Tool".
6. The DSDownloader will ask you if you want the "Original Backup" or the "Last Tune Written". Click "YES" in order to export a copy of the "Original Backup" tune file from the Predator.
7. Once the file has been exported from the Predator/Trinity, the DSDownloader may ask you if you would like to save it in the ".ori" file directory. Choose "NO" and select your own folder location, or your desktop, to save the file somewhere so that you can find it easily.
8. Your "Original Backup" tune file is now saved to your PC.
9. Now, Repeat the steps above in order to export a copy of the "Last Tune Written" - because the tuner creating your custom tune for you will need BOTH files. So, from back at the Express Tune page in the DSDownloader, click "Get tune file from Tool".
10. The DSDownloader will ask you if you want the "Original Backup" or the "Last Tune Written". This time, Click "NO" in order to export a copy of the "Last Tune Written" tune file from the Predator/Trinity. This file is a copy of the current diablo tune installed in your vehicle.
11. Once the file has been exported from the Predator/Trinity, the DSDownloader may ask you if you would like to save it in the ".ori" file directory. Choose "NO" and select your own folder location, or your desktop, to save the file somewhere so that you can find it easily.
12. Now your "Last Tune Written" tune file is also saved to your PC.
13. Post up both of those tune files...
ednis187
Post by ednis187 »
Ive update the Predato to 9r14
Now ive download the Original Backup but i want drive the 91 Oktan Tune in Germany.
How can i post the Tune here?
Camaro 2SS L99 Black in Black with Black Stripes and Sunroof.
Tune by Diablosport Predator, SLP Loudmouth II, Afterbourner Taillight, Custom Ambientlight, Xenon Side Scoops.
In April: SLP Blackwing full CAI
follow those instructions up there ^ ^ ^ ^
it also tells you how to export the "last tune written" - which will be the copy of the diablo 91 octane tune that you currently have installed in your car...
ednis187
Post by ednis187 »
Okay now ive both of tunes and now?
How i can post the tunes here>?
lol
click the "post reply" button at the bottom, under this quick reply window... that will give you a section where you can attach the tune files to your post to get 'em up here...
ednis187
Post by ednis187 »
06MonteSS wrote:lol
AAAhhh OKAY :D
Here are the both Tunes
91 Oktan tune.grg
(3.25 KiB) Downloaded 144 times
original.grg
(67.36 KiB) Downloaded 196 times
ednis187
Post by ednis187 »
Thanks a lot for your Help :D
2sscamaro
Post by 2sscamaro »
hey SIERRA BOI... see if you think this camaro needs the limiter bumped up!!! :lol:
http://www.youtube.com/watch?v=eh3-4290 ... r_embedded
