I haven't used the predator in a while, and I am not sure what tune I left it on. I wanted to restore orig backup so I can get the Ford cps recall done, and after selecting the tune and turning the switch off for 3 seconds, the tuner says turn ignition switch on, then it immediately goes to a error screen about how i didn't turn on the ignition switch. following info is in tuner:
2003 CFC
Snapper-1064425532
Ford_7_3_7r196Z
8/3/04 12.02:27 AM
VNAA8U5
Any help is appreciated. Thanks. Steven
2000 7.3 fails to recognize ignition on
RE: 2000 7.3 fails to recognize ignition on
Sounds like a possible feps circuit issue with the tool, it may need to be RMA'd for repair. Call up tech and see if there is anything they can do first and then they will point you in the right direction
Don
2002 WS6
2002 WS6
