U7131 and Data Viewer
Kasey
Post by Kasey »
Updated my Predator today to the latest crom file. When I looked I saw the info on the Data Viewer. Installed it on my computer and after the crom update decided to try out the Data Viewer. It finds the Predator, Predator says it's under remote control, but the program just sits there saying it's aquiring information. In the status bar it says its transferring info. So it stays stuck on this and never displays anything else. HELP!?!?
'07 Dodge Cummins 5.9
U7131 Predator running 9r04
Windows Vista SP2
Radio Shack Serial to USB cable (installed driver under compatibility mode - works fine for DSDownloader)
Any ideas?
Kasey
Kasey
RE: U7131 and Data Viewer
Post by Kasey »
...oh and I tried to call first but waited for 8 minutes the first time before I was just disconnected. Second time it was 7 minutes or so of the pre-recorded stuff, then it rang, sounded like someone picked up, then silence for about 15 seconds, and then went back to the recording saying that everyone was busy and my call would be answered in the order it was received, etc, etc, etc...
jimb
Post by jimb »
Close DataViewer (File->Exit), and post the runtime.txt file found in: "My Documents\DataViewer". It will give us a clue where to look.
Kasey
Post by Kasey »
Here it is...
3792321 Info: .\DataViewer.cpp, line 161, CDataViewerApp::InitInstance, DataViewer Version 3.2.0.7
3792321 Info: .\DataViewer.cpp, line 162, CDataViewerApp::InitInstance, The DataViewer is initializing.
3792509 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
3793008 Error: .\comm\CommThread.cpp, line 479, CCommThread::TestOpenConnection, Baud Check bad response: 5A
3808280 Error: .\comm\CommThread.cpp, line 479, CCommThread::TestOpenConnection, Baud Check bad response: 5A
3823537 Error: .\comm\CommThread.cpp, line 479, CCommThread::TestOpenConnection, Baud Check bad response: 5A
3830963 Assert: .\data\LiveDataBase.cpp, line 72, CLiveDataBase::SetUseBus, Assertion Failed!
3830994 Info: .\data\PidRecordMgr.cpp, line 89, CPidRecordMgr::Load, Begin Load() of data for vehicle 2007.0 - Chrysler - - - : CALID = 45325753AB
3831025 Info: .\data\PidRecordMgr.cpp, line 93, CPidRecordMgr::Load, Reading pid records, found: 370
4097132 Info: .\comm\CommThread.cpp, line 177, CCommThread::ExitThread, CommThread::ExitThread complete.
4097132 Info: .\DataViewer.cpp, line 285, CDataViewerApp::ExitInstance, CDataViewerApp::ExitInstance complete.
jimb
Post by jimb »
The Error: .\comm\CommThread.cpp, line 479, CCommThread::TestOpenConnection, Baud Check bad response: I'll need to look into further. Might be the USB-Serial driver. May want to use the Prolific USB driver instead (see: http://www.diablosport.com/index.php?na ... 4935#24935)
I just tried Predator U7131-9r04, Prolific USB-Serial on WinXP using DV release 3.3.0.3 on bench and it streamed OK.
Kasey
Post by Kasey »
I'll give the Prolific driver a whirl...think I've tried it before though and it wouldn't work with DSDownloader but I can't remember for sure. I'll also try the Beta of Data Viewer. Thanks!
Return to “DataViewer/DV2”
