WOT data log (monte)
mcirullo11
Monte could not get to load into DS could you look at it
mcirullo11
RE: WOT data log (monte)
Never mind i found my mistake i did not record RPM when doing it. I think that is why is not letting DS review it
yep... have to have that required parameter....
mcirullo11
i could not find rpm to log is it listed as something else. Please list everything i need to log so i dont need more then i need to
Engine Speed = RPM...
here's a list of what to log...
air fuel ratio (Equivalence Ratio) -- you will only be able to log this if you use a laptop and the dataviewer program for logging
commanded throttle position (or Absolute Throttle Position)
engine speed (RPM)
intake air temp
long term fuel trim bank 1
long term fuel trim bank 2
MAF Sensor Mass Airflow
spark advance
total knock spark retard (or Knock Retard)
engine speed (RPM)
intake air temp
spark advance
mcirullo11
- aviraled2002
mcirullo11
go into the options and make sure it's selected to show the infrequently used PID's
it's in there somewhere man, for sure... Engine Speed (rpm) is available when logging with just the predator, so it is definitely in the dataviewer somewhere....
