new predator user questions
I just bought an 06 mustang GT. It came with a K&N CAI, BBK TB, underdrive pullies, BBK shorties, Flowmaster axle back and a Predator U7140 complete in the box.
I think the car has the provided Diablo performance tune in it but how can I tell.
I would like to experiment with small increases in the timing and shift firmness. Is this OK? Recommendations?
Would the car benefit from a custom tune now?
Kevin
Kevin
To determine which tune is currently loaded in the car's ECU, Select 'Options'/'Last Tune Written' in the Predator's menus.
It's not recommended to change the timing values, unless the engine is experiencing pinging, or you want to use gas with a higher octane than the tune, e.g., 93 octane gas with a 91 octane tune(increase global timing by 2 deg).
If you're referring to a dyno tune when you say 'custom tune', then that's always a good idea, since every engine is different. But obviously it will cost $.
bullitt1668
How much some thing like this can cost?njctd79 wrote:Although a dyno tune is not out of the question I was referring to a tune emailed from a tuner like Bamachips built around the specs of the car.
All I have, engine performance, wise is 3.73 gears, off-road h-pipe, k&n cool air intake, and pulleys. And of course... the Predator (u7146).
2001 Kenny Brown Mustang Bullitt
I believe that Bamachips can do a tune for $75.bullitt1668 wrote:How much some thing like this can cost?njctd79 wrote:Although a dyno tune is not out of the question I was referring to a tune emailed from a tuner like Bamachips built around the specs of the car.
bullitt1668
Yeah, aftermarket throttle bodies often cause this issue.
Try removing it and replacing it with the stocker, all should be fine.
